Caliper is ok.Looks like a bad caliper too.
Let me know who you use. Got to cross this bridge next year!Any recommendations on body shops in the area? I think it's finally time I got my dents pulled and get the truck painted.
I used a guy@Montanaconner recently had some paint & body work done pretty inexpensively & intends to be at next Wednesday's gathering. My 62 is still sitting at body shop but I'm not pushing getting it done due to Clemson tuition!!!
i got mine done about two months ago- not perfect, but exactly what I wanted- and sub $2k. I knew that I was just going to beat it up again, so I had him pull out the Major dents and repaint. I have before and after photos and videos I can show on Wednesday!Any recommendations on body shops in the area? I think it's finally time I got my dents pulled and get the truck painted.
Who do you longtime locals use for automatic transmission repair and service?
So long story short, I had an alignment done on the 80 a few weeks ago while I was in VA after replacing tie rod ends and replacing suspension with OME stock height springs. The truck still wanders and follows cracks in the road and any little bump requires a steering correction. It was clear to me the alignment tech didn't know his butt from a bag of rocks when it took him an hour to realize there is a tie rod behind the axle. Where do you guys take your trucks for alignments around the Greenville area? I can't stomach another 500 mile trip to VA with steering like this.
Who are you all using for your vehicles a/c work? I want to have the r12 pulled and I guess I will go with the redtek12a replacement kit. Seems to get decent reviews.
Or if anyone has negative experience with the redtek please let me know.
Thanks
Check your hub nuts too?So long story short, I had an alignment done on the 80 a few weeks ago while I was in VA after replacing tie rod ends and replacing suspension with OME stock height springs. The truck still wanders and follows cracks in the road and any little bump requires a steering correction. It was clear to me the alignment tech didn't know his butt from a bag of rocks when it took him an hour to realize there is a tie rod behind the axle. Where do you guys take your trucks for alignments around the Greenville area? I can't stomach another 500 mile trip to VA with steering like this.
I did get a report but I don't trust it. The report showed castor to be within spec. Toe was out and showed adjusted to within spec. After alignment there was no appreciable improvement in steering and handling. I will be bringing it to Mauldin per your recommendation. Stay tuned.Goodyear in Mauldin. That being said it sounds like you may need a set of castor correction bushings. Slee sells a set. Since you don't have a big lift you might not need them set very much.
Did you get a report with your last alignment?
And that solves that! Let me know. ThanksWe just bought a machine that does both. It might be a few weeks before we have it up and running.
