I have been using the Terrain Tamer rotors and pads on 60 series builds for a while now and am very happy with the performance. I can get them to lock up without a whole lot of bother.
Trying to order parts for the maintenance, regearing, locking of the Lx450 axles. Already ordered the rebuild kit. Want to upgrade brakes while I’m at it. What is everybody upgrading to? Rotors? Pads? Brake lines?
I was just going to go with Toyota oem parts. Unless someone has real world experience with something that is actually better.
Any advise on the purchase of a used winch would be greatly appreciated.
Just don’t want to spend the money for a used one that I could spend for another model in new condition and then find out that it was one of those too good to be true deals
For Sale - Warn 8274-50 Winch
Not necessarliy advice but personal experience. I picked up a used 8274 6 years or so ago from a mud member for 600 bucs. It was been cleaned up but wasn't mint and not near as nice looking as the one you linked. I purchased a couple things from warn and wired it up. Has worked great every time I've used it.
Unless they are royally ****ed then things like solenoids and such can be replaced. Or like Johnny did, swamp in a new motor. 800 is a good price for a clean working 8274' they're like 1900 new.
Thanks
I contacted the seller already. To the best of his knowledge it is in very good condition with very little use. I researched a little and read a few threads in tips and advise on buying a used winch but as usual I rather just ask guys here. I tend to put more weight on responses I get from you guys here than what I read online from random people.
Thanks
I read about the 100 series pads. Does not improve brake performance. They just last longer. So might be worth going that route.
FWIW i was not able to run the 100 pads with new rotors and old calipers even after removing the shim. The calipers must have worn into a happy range and would not open wide enough to run the 100 pads. New calipers at same time and it might not have been an issue.
cool thanks. I will check out the tiger shark.If that doesnt work out for you, check out the sale price on the TigerShark 11500 SR: Superwinch Tiger Shark
Well I was thinking about putting in front of the mini. I plan to build my own front bumper for it so there would be no need to try to fit it into a particular existing bumper.Also, what are you putting it on? It's a big bitch but fits the front of a 40 or 60 nicely. Depending on the bumper you plan to run, I'd probably choose to run some thing a bit slimmer on the mini or 80. I had a m8000 on my 80 and liked it.
I decided to not go with the 100 series pads. I ordered ebc pads front and rear.Ill add I ran the 100 pads for a a few months. I was getting a weird feedback through the pedal with them when I stopped. I swapped back to the 80 pads and the symptoms went away.
Also Couldn't tell a difference in stopping. Felt better about putting it back to what is was designed to have anyways.
I have EBC greens with OEM rotors (100 series pads in the front). Good stopping power but after removing the leaking and out of adjustment LSPV in the rear, I have great stopping power.
Similar .... I was getting way too much brake fade when in the mountains. Step one was cut loose LSVP lever from the axle and zip tie it for maximum rear bias (which is still short of allowing the rears to lockup first) ... then put EBC greens up front. Last trip to the mountains was much better.
Can you elaborate on the this. What's involved? Now that I'm getting my steering dialed in, my brakes are next. My pedal has way to much of a "spongey feel"
I've been looking a adding a set of Wildwood calipers. Jonathan at TLC runs them on his resto 80's.
