I have a 94 FZJ80. The turn signal cancels, for lack of a better word, right after a quarter turn of the steering wheel to the right. It only happens when I turn right. What could be causing this?
Not! I pulled and hurt my hands trying to poop it offs.Also, I've found that a puller generally isn't necessary for toyota steering wheels as long as they haven't been overtightened. Usually grabbing the wheel at 3 and 9 and rocking it side to side will pop it loose once the nut has been removed.
Took mine apart and lubed. Don't think it will help much as it still does it when parked. Not sure what part makes is short return? Something might be worn but I don't see what it is. The lobe on the red arrow bumps the arm on the yellow arrow to cancel the turn signal. Doesn't looks like much wear.
