My lord sounds like you in contentions with the supra guys runnin 4.7 toyota v8 w/ twin turbos MY my
Wow man, that looks really really really good! The wideband will really help when you start pushing more performance. If you would not mind much can you post your AFR's with the 5psi you have now, and then with the increments of psi you choose, whatever you choose, as you go up? I'm still trying to figure out if we can "tune the AFR's" by adding more boost; I'm trying to visualize the graph and the relationship (direct, inverse, linear, curved) between boost and AFR. In other words, it is pretty well confirmed that with approximately 6.5 psi of boost the 1FZFE will run really rich at WOT (10.8 AFR's or richer!) I'm wondering if we were to goto 7.5 psi would the AFR goto 11 something, then 8.5 psi to 12 perhaps? Or is the 1FZFE always gonna run crazy rich up to the point of exhausting the fuel pump or the fuel injectors' capacity? Since you're starting low and you have to go up some, it will help to have that data. Anyways, again, your setup looks awesome! Excellent Work.![]()
how much driving time have you given the ECM to adjust? And what is the AR on the hot side?
So far every truck whether super charged of tuboi charged and running different amounts of boost with my MAF always comes in at 10.8 AFR at WOT. I honestly don't think you are going to be able to tune the AFR by modifying the amount of AIR.
I think you need to alter the FUEL and URD has what I would use if I ever get to that point. URD MAF Calibrator
My plan is to run 10psi and monitor the a/f along the way.
Mike
The truck is running 10.8 only at the last 300-400 rpms.
Also my Fuel pressure regulator is not hooked up to a vacuum line. Your instructions said to leave it off. Should I hook it up with a boosted truck?
Mike
Nice project. What are you using for fuel control? I noticed sombody posted about not being able to do much with the AFR just by playing with the AFM. In my experience, I agree. Are you planning on some sort of fuel supplement for your part throttle conditions?
I think 12.5-1 would probably be the richest you would need under any condition. I wonder if you could lower the fuel pressure and run a programable aditional injector controller. The fact that the FZJ's run rich at the top end under boosted conditions is somwhat puzzling. Most vehicles I have turbo'd have exactly the oppisite effect. Are you aware if anybody has had success with an Apexi AFC on the FZJ computer? That might allow you to richen the lower zones and lean the upper zones.
I know that battling the open/closed loop and transition period can be somewhat of a challenge. Good luck and keep us posted.
anymore updates on this?
