Completed the Turbo install this weekend.
Wideband is on it's way but not yet installed.
After driving for a little, I got a P0125 engine code. Checked voltage on bank 1 02 sensor and it was reading zero.
Had suspected it got messed up during the removed process from stock exhaust. Cruising at 70mph, EGT read between 1000-1150. (EGT is about 4 inches after turbo, not ideal I know)
TODAY:
Replace 02 with suitable bosch replacement. Voltage on bank #1 was now reading and check engine stayed off. All seemed good.
Shut off truck for 5 min and restart. Got P0135 Code. Clear code and went for a 10 min drive.
Code P0125 reappeared after a few mins....
EGT's now sitting at 1200 and would clime if I added any boost.
Turn off truck for 20 mins while eating dinner. Back on the highway and EGT's seem fine again, not going over 1200 even with 6-7lbs of boost at intervals.
Any ideas on what's causing the P0125 and should I be concerned about the EGT's?
BUILD Specifics:
- MSGgrunt Turbo setup. T-62.
- Tweak many little things about the setup, but overall no major changes.
TODAY:
BUILD Specifics:
