@Mr Coaster1990
looking at the specs on that, the turbine wheel is the same size as what's used for the 4.2 litre 1HD-T 80 series landcruiser engines.
That's not necessarily a problem by itself because turbine characteristics are also very much dependent on the #cm2 specification on the turbine housing.
This relates to the size of the nozzle that directs exhaust gas into the turbine.
Big cm2 housing equals slow response from the turbo, slow to build boost, but will keep boosting into higher rpm.
A smaller cm2 housing spec means a more focused stream of exhaust gas into the turbine wheel, faster to build boost, more responsive to throttle, but will run out of steam at higher RPM (not gonna be a problem with a 4.2 litre turbo on a 3.4litre engine).
Think of the turbine housing like a garden hose, and the turbine wheel as a BMX bike wheel. If you tighten up the hose nozzle and spray a fine jet of water onto the bicycle spokes at the wheel rim, the wheel will spin fairly easily, and accelerate fast. If you loosen off the nozzle so you have a soft wide stream of water from the nozzle, the wheel takes longer to get spinning, and won't spin as fast.
Now, think of the same garden hose and trying to spin up a big mountain bike wheel. it's not gonna get moving as fast, and won't spin as fast. The greater mass of the big wheel also means it will respond slowly if you increase or reduce flow through the nozzle. This is how an oversized compressor wheel will behave.
If you have the correct size turbine housing (nozzle) to drive a suitable sized turbine, paired with a big compressor wheel, the turbo will push a lot more air at lower boost pressure (good), when and IF you get it spinning fast enough.
In a heavy bus, you want a turbo to respond early and respond fast so you get maximum low end torque. As you said, high RPM high speed output is less relevant to your needs.
An oversized compressor wheel is geared toward high RPM performance right off the bat, and turbine specs become more critical.
Kinugawa haven't listed the cm2 spec for the turbine housing on that turbo, and the casting number on the exhaust housing corresponds with the housing numbers for a 1HD-FTE turbo. This isn't possible. The 1HD-FTE turbine housing and the turbine size they list aren't compatible. Also, the 1HD-FTE housing isn't compatible with the CT26 CHRA (central housing that holds the shaft and bearings).
This is one problem with Kinugawa. They have mixed and matched castings from different turbos to make their own reproductions.
In the past, it was common for them to list turbo specs as "stock" and have them wrong.
Casting numbers often don't match the description.
They also had # cm2 information incorrect for different versions of the CT26, if they published it at all.
This all may not matter if the turbine housing actually is a direct swap for a 13BT housing, but when they haven't published complete specs, you're at the mercy of unreliable or incomplete information.
