UPDATE 5/1/2013. The fully plug-n-play setup is now available for orders. Information as follows:
We will have a few different options for you guys.
* One setup will be hardware only for a plug and play tunable setup for the guys that want to do the tuning themselves on more modified setups such as custom turbo or supercharged trucks.
* Another setup will be package with the plug and play hardware which includes two tunes that can be switched between (power tune and gas mileage tune, and possibly other tunes).
Finished the final layout for the plug and play harness tonight and tested all functionality including MAP clamp, O2 sensor remapping, ignition timing adjustment, fueling adjustment, etc... Everything is working perfectly.
Just for kicks and a quick and dirty test I went ahead and leaned out the majority of the fuel map and added a few degrees of timing in certain load areas of the ignition map. The increase in power was very apparent with just a quick drive on the side roads and highway. This was just a rough test to test functionality to make sure everything is doing what we want it to do, but the power increase was very obvious with just a couple of mild changes.
Starting today we will begin taking orders for the following:
* Complete plug and play kits including ECU
In the next few weeks we will have the following available as well:
* Complete plug and play kits including ECU and pre-loaded switchable power map and gas mileage map.
Why use the EMSPowered plug and play setup?
* It is easy to install. It all plugs right in and to go back to 100% OEM Toyota all you have to do is unplug the EMSPowered plug and play setup.
* It gives you full control over the ignition timing map.
* It gives you full control over the fueling map.
* It allows you to simulate any reading you'd like on the O2 (oxygen) sensor signal if you want to avoid any check engine lights or erroneous fuel trims.
* It enables you to properly tune for forced induction such as turbocharged or supercharged installations.
* It enables you to properly adjust for larger fuel injectors.
* You can achieve better gas mileage with the proper tune.
* You can achieve better power/torque with the proper tune.
What else is important here?
* EMSPowered will continue to develop new solutions based around this plug and play setup over the foreseeable future for the Land Cruiser 1FZFE platform.
* As we develop newer tuning maps you will be able to take advantage of them by simply downloading and loading them onto the tunable ECU.
* If you purchase one of our turbo kits in the future, you can simply load a pre-tuned map for our turbo kit onto the tunable ECU.
* The point being here, is that it's not necessarily "what you see is what you get". This tuning solution will continue to get better and better as we put more time and $$ into development of new and better tuned maps. And to take advantage of those new maps, there is no change of hardware required, all you have to do is hook up your laptop via the included USB cable and load the new tuned map.
We will keep pricing and package information updated on our website as more options get added. You can see pricing information and place your order on our website here:
http://www.emspowered.com/storefron...ct_info&cPath=61_119_120_312&products_id=1151
