hi guys.
I'm in a bit of a panic here.
my truck has had the charge light coming on since I bought it. it is intermittent light sorta thing.
today I put my digital multimeter on the lighter socket to monitor the voltage.
when I left home the voltage was 14.25vdc and the charge light was on.
it was like that most of the way to work.
then the lights went off (normal Dash display now) and the voltage jumped to 16.25 and it slowly creeped up and actually touched 18vdc by the time I got to work.
when it touched 18v the abs light flickered on. once I got to work i verified on the battery directly that the voltage was high and it was.
i'm thinking this has to be a problem with the wires that go into the side of the alternator.
I'm looking in the FSM and cannot see where these wires go.
any ideas?
EDIT:
I pushed on all the connectors in teh charging circuit before I started the truck to drive home after work.
the voltage stayed at 4.15 all teh way home and the warning lights stayed on.
I ordered a new Alt.
What concerns me is that when the thing is working properly (outputing 14.25Vdc) the charge and Parking brake lights are on. When the lights go out, the alt is outputting too much voltage. explain that....
any ideas?
EDIT:
