Builds TRDdrew's build: let me introduce Waffles
Finished up replacing all the coolant hoses, cleaned the throttle body and got her all buttoned up and filled with coolant. Also modded the air filter cap to get rid of the air pump connection. Finished by removing the rear heater and making a sandwich style block off plate similar to the one wits end used to sell
Long live the mighty 3FE
Started and sort of finished the install for the OME J lift I got from a club member. Got the fronts in, trimmed some rusty backplates, removed the front sway bar and extended the front diff breather. Pulled the truck out to flip it around to do the rear and now it's sitting perfectly level so I'm leaving it. I have almost no weight in the back so this set up makes sense.
It's now ome J's in the front with 860's out back. J shocks all around. Drives great, if I ever add a back bumper (cough cough @CrabCake ) I can swap in the rear J's.😎
Time to get the 35's mounted and then that will give me the motivation I need to get the new axle housings installed
BEFORE
AFTER
BEFORE
AFTER
LOL...looking good and rear bumper coming soon! 🦀 🦀
