Here's the skinny-
I drive a 1989 hj61 with approximately 270,000 kms (167,000 miles) on it.
Specs - Turbo, Intercooled, 11psi of Boost, 3" straight pipe from the dump, and Tru-cool 30,000lbs transmission cooler. Running on AMSOIL fluids.
I picked up the truck in October and have put 22,000 miles on it since then with standard service throughout my brief ownership.
A month ago I was driving up Vail Pass 10,662 feet (3,250 m) at a 7-8 % grade and my transmission oil light illuminated.
Right afterward I pulled over let things cooled down and made it home without issue. I promptly ordered an aftermarket transmission cooler a Long's Tru-Cool http://www.amazon.com/Tru-Cool-LPD4...l+Max+LPD+30,000+Transmission+Oil+Cooler+4921 which measures to 8.5"x22.75"x1.25" a perfect fit in front of the cruiser.
Things have been fine for about a month until this weekend....
Driving back and forth to Utah from Colorado up and over the Eisenhower Tunnel 11,158 ft (3,401 m) and Vail Pass I felt no troubles until my transmission light went on again heading up the tunnel some call it the Ike Gauntlet http://www.tfltruck.com/tfltruck-hall-ike-gauntlet/ . Truly I see test/concept/mule trucks and cars wrapped in stickers being tested going up and down this road until something breaks.
Yes I know I drive a 25 year old truck and asking it to go 50mph up a pass this high at elevation and grade is asking alot but....
The light went on and stayed on until I made it through the tunnel and went off about a minute later as I descended. Upon arriving at home I checked the trans fluid and it smelled significantly burnt.
So the next step is what?
Change my trans fluid/Rodney Flush?
Fan Clutch?
or go DEEP
Drop the tranny, rebuild, and put in a rebuilt Torque Converter?
or
5 Speed?
OR?
Fan Clutch?
or go DEEP
or
5 Speed?
OR?
