Transfer case Spring replacement (1 Viewer)
Palm Harbor, Florida
In trouble shooting my transfer case slipping out of 4h and 4l- It has been mentioned that a stronger spring would be needed. What would be involved in switching the springs out and where would I source? CDAN? I was told you dont need to drop the xfer case to get to the springs.
Kansas City, MO
Easy to do
See this thread: Detent springs
It has the TSB about them and a nice pic of where it is located. You unscrew the cap, remove the spring and put the new one in. I used a small piece of wire with a hook bent into it, to get it out.
Good luck
Ex
Meridian,TEXAS
Hope the spring helps........
Most slip-out effects are cured by replacing high/low gears and sliding collar.........
In car land TSB means "Technical Service Bulletin." However, TSB does have other meanings outside of cars...
Dynosoar
Slightly Disturbed
SoCal
Did you check your motor mounts? This is a common problem with a failed motor mount. When torque is applied the drive train will twist and force the shifter against the body making it pop out of gear. To test have a trusted friend sit in the truck with the e-brake on. Have him/her put the truck in gear and start to let the clutch out. You will be standing on the driver side of the rig with the hood open. When he/she lets the clutch out you should not see the engine move. if the engine lifts on (on the drivers side/left side) you have a bad motor mount.
Dynosoar:zilla:
Ok finally got around to pulling the spring today. Streched it a bit and put it back. Took on a test drive and stayed in 4low, only when I tried to climb basically a vertical wall just to test it did it pop out. I will call Marlin tomorrow for a stiffer spring. Thanks for the help, I am glad that is all it was.
Dynosoar
Slightly Disturbed
SoCal
Check your engine mounts!!! That is a typical engine mount problem.
Dynosoar:zilla:
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
