Once I get my set I will do a write up on the install when Im able to actually do it.. I will also report on how they break in with periodic oil changes and drain plug magnet inspections for shavings and what not... Should be a PITA but a necessary evil for long term durability and confidence in the gear set. I plan on driving my rig ALOT as it is our camping and exploring rig!
dear sres i reed all these threads and at this time i am very confused me lc hdj80 turbodiesel 1995 have 265/70/16 stock tyres the diferential ratio is 41/10 manual transmission 5 speed in highway at 2600 rpm its 110 kph i need regearing the transfer case to give 110 kph at 2200 rpm is it posible?
thanks in advance and excuseme me english is not the best
@OTRAMM just installed both sets for me in a spare transfer case I picked up with low miles. If he sees this maybe he can provide feedback on the install. The transfer case won't be installed until next week and I don't know when I'll pull the trigger on the 315s, maybe not until the Spring but we'll see. I might not be able to stand waiting.
@iptman 's gear install went smoothly. I took a bunch of pictures that I need to get around to uploading. It wasn't a difficult job but you'll need a press and a decent set of pullers or some creativity.
I received my gear set a couple weeks ago. but it will be a while before I can install them. Probably going to be a winter project with a spring install.. 31/34 tooth gears for a reduction of high range.
Good looking gear set!
I believe @orangefj45 is the current distributor of these. As for strength, they should be cut by the same Japanese supplier who does the OEM gears, if I remember correctly.
what only 10% im looking for disassembly me transfer case and make a new kit of gears for minimun 20% od me engine have a lot of power me manual transmission is 5 speed but i dont use the first i move the lc with the second i need more od
I did. Been running them for a couple months now with 285s, will get 315s in the spring. I've had no problems with them at all, no weird noises or anything. I'll do a drain and fill on the transfer case once temps rise a bit here locally and see if there's anything no bueno there.
265/70/16 tires are smaller than stock, at least here in the USA. 2600 to 2200 rpm is close to 20%. I think you need to get 315/75/16 tires to get the gearing where you want it.
I ran my GPS and scan gauge this morning on my way to work and on worn down 285/75/16 Goodyear MTRs I registered 2150 RPM at 60 MPH on a fairly flat section of road. I don't actually know what this was on the stock gears so if someone could do the same I'd be interested to know the real world RPM difference.
