I have been chasing a vibration for 800 miles now. It is a harmonic that is in your butt/dash at 60 MPH. First, I change all 4 u-joints because one had a small hang up. No change. I take the driveshafts and get them balanced. No change. After a bunch of other tries, I go old school. I know it is Dangerous because there is a reason farmers/ranchers are in the Top 10 deadlyist jobs. I put the truck on 4 jacks and start it up. Find big vibration at 27 MPH. Hear it, feel it outside with my hand on the truck.
Take all 4 tires off, turn front/rear lockers on, Lock center diff, Same vibration
Take rear driveshaft off, Same vibration. Doesn't matter if selector is in "D" or "2"
Take front off, Now No driveshafts, Not smooth, but nothing like before.
Replace rear driveshaft, remove front. Its definitely back, just not as loud, but still bad-bad
Take front off, take rear off again, replace front with OLD one from scrape metal pile, Big vibration
Put In LOW, tranny in "D", run it up, Not as loud, but can be felt outside for sure. Engine is turning some RPMs now so it is not as easy to hear.
To recap, No vibration when driveshafts are removed, but a little vib at 60 MPH. Vibrates like crazy when only front or only rear is on. Vibrates same when old worn out shaft is on front only too. I think I have eliminated the entire rear end, front end, and driveshafts. Next in line is transfer case.
Can't feel play in either output flanges. Only have wet dirt at speedo connector. Even sent transfer oil to Blackstone, and they said negative bearing metals.
I am going to lay down the time and money to get a used transfer case Monday unless anyone of my Cruiser brothers has another idea or suggestion. Thanks for any help/ideas you can give me.
