Transmission temperature by scangauge - my $0.02
Having the transmission temperature sensor available is one thing, getting the data from the ECU is another. No doubt about it, the sensor is available in the vehicle. The sensor provides a voltage to the ECU, and the ECU calculates the sensor resistance from this voltage by using the well-known Ohm's law. From the sensor resistance, the ECU uses a look-up table supplied by the sensor manufacturer, to match the resistance to a temperature.
The problem with the LC is that the ECU should be called a powertrain control module, in that it performs the task of running the engine as well as the transmission and probably also the transfer case. The proof of this lies in the fact that there is no separate control module for either the transmission or the transfer case.
So if the ECU does all these calculations internally, it doesn't have the need for sending the data to the outside world. Of course, if you knew what command to send, you could retrieve the data from the ECU.
Toyota did not make this ECU, it is from Nippon Denso. They are the ones who would know, and I am 100% sure Nippon Denso engineers in Japan, if you could find one who spoke english, will not give out such information.
What Scangauge can do:
Get a new trans temp sensor, and figure out the voltage/temperature curve. Then provide 1 analog input channel for the scangauge, as well as a socket which will split the voltage wire from the sensor into 2 parallel lines. One still goes to the ECM, the other connects to the analog input channel of the scangauge. With the curve stored in the software, the gauge can then measure the voltage, convert it to a temperature and display this data.
Personally, I don't think scangauge will modify its product just because some folks want to get information they shouldn't really be worried about.
The information you would get will not be useful to anyone. If you overheat the tranny, the warning light comes on. That should be enough for a smart driver to pull over.
