With no way to get Transmission Fluid Temps from my ScanGauge, I wanted to install a gauge of some type in order to monitor transmission temps.
I chose an 'Auber' digital gauge because it is small, accurate and allows for minimum and maximum alarms. It can also be used with a visible and audible warning buzzer (if wanted).
You can set the parameters where the alarm(s) come on and drop back out.
I thought a good place for this gauge (and another to monitor Oil Pressure) would be where my broken cup holder used to reside.
There is a large void behind the dash at that location which accommodates the length of the gauge and the necessary wiring quite nicely.
It so happens that two of these gauges will just fit into the face-plate of the cup holder (if you cut the sides and top out of it), but I opted to fashion a facsimile out of aluminum angle since the plastic is so brittle.
Continued next post:
