Hi all,
Lots of rain here in SC and I had plenty of time to tear down and reseal my tranny and transfer case. I drained a lot of fluid out of the tranny and almost zero out of the transfer case. So, I guess it was due for some work.
All seals looked dry and brittle. When I pulled the nose (front drive section) off of the TC the needle bearing must have been frozen as it fell apart. That section of the TC was packed with gunk. I guess the front seal was so bad that it let dirt and mud get in. Need to get a new bearing.
My big concern is the tranny output shaft. It looks like the shaft has some wear and I just wanted to to know if this looks excessive or normal? The splines are impacted/worn but don't appear cracked. What would you guys do? I really wasn't planning on taking the gears apart, and that may be above my pay grade, so it may ned to go to a shop to repair this. Of course I noticed it after it was put back together and painted!
