Trail Gear has 5.29 Hi Reverse gears for about $75-100 cheaper than anyone else. Does this mean they aren't worth buying, or does it mean get these if you're on a budget and dont worry they aren't going to break.
Buy them if you dont care about ethics, back stabbing, stealing designs from other companies, or supporting china. They are the only company testing their products though.
mike
My buddies TG gears are holding up just fine..
We all shop at walmart, and are good Americans who supports all kinds of Horribly unethical companies, hell our country is run by unethical people, Why have a double standard when buying crap for our rigs?![]()
I dont see them as being any worse off than walmart, and the whole copying thing...who knows, coulda been a race to be first and TG just lost.
when i see a vendor selling gears for $75-100 less than other vendors then i have to ask myself "how can they be so much cheaper"?
I just ordered some 4.88 sierra gears from cruiser outfitters which were a good 75 dollars cheaper than almost everyone else, and i was asking myself the same questions. The response i got from kurt was volume and lack of name brand associated costs. It very well could be that because trail gear seems to have a high volume/low cost sales style that that could be a big part of the reduced cost.
-Matt
Which begs the question of where BOTH of them buy their gears? If they're both Chinese, there may even be a connection. How deep do you really want to dig?
here's another thought and it's all about tech:
why would anybody want to run 5.29 gears, and on top of that in reverse pattern?!
any gearset for a toyota third is notoriously weak if you go 4.88 or lower. besides that, reverse cut gears are even lower since the pressure gets excerted (sp?!) on the coast side of the gear.
so running 5.29s in reverse cut does'nt sound like a great way to go.
if this were my rig, i would put a doubler in it and run 4.56s or 4.88s . set it up so the gearing works well on the highway and the doubler will give you more than enough low range.
that way you'll have the best of both worlds: strong gears, super low gearing, your choice of tons of different final drive ratios and freeway-ability.
but that's just me.![]()
That's incredibly poor and innacurate information. 5.29's are plenty strong if setup properly - I've run them in 3 vehicles residing behind crawlers w/o a problem.
You are also incorrect about Reverse Rotation gears - When installed in a HP pinion on the front, the pressure will be exerted on the drive side rather than weaker coast side of the gears. I've run HP's in two vehicles with never a problems - with properly setup gear sets.
