Just purchased my new-to-me 2008 LX570 after initially searching for a 2013-2015. The threads on MUD have been more helpful than I can say, so I wanted to contribute back to the community.
While there are many threads on specific mods or services, I searched for a consolidated baseline checklist to follow after buying my rig. My mindset while searching for my LX570 was that mods/service would fall into 3 categories:
1. Must-Do Service (Regardless of year/mileage purchased)
2. Higher Mileage Service (100k+ miles on rig purchased)
3. Best-practice upgrades (100% optional)
I'll include my list below approximate DIY cost.
Please comment with other things you'd add. I'll promise to come back and update the initial post with your recommendations, so we can have a consolidated list.
- Oil Change ($55): 7.4 qts of OW20 + TRD Oil Filter
- Rear Differential Fluid Change ($50): 4.44 qts
- Front Differential Fluid Change ($25): 2.01 qts
- Transfer Case Fluid Change ($25-$130): 1.53 qts (Price varies if you get Toyota OEM 75W)
- Engine Air Filter ($25)
- Cabin Air Filter ($20)
- Lube Propeller Shaft & Zerk Fittings ($10) - Suggested by @Sandroad
- New PCV Valve ($15)
- Radiator + water pump + fan clutch + thermostat + belt tensioner + idler pulley + fluid coupling bracket + serpentine belt ($1100)
- New Coolant ($110): 17.6 qts
- New Brakes & Rotors ($530): I chose Powerstop Z36
- Headlight restoration kit ($20)
- 8 x Spark Plugs ($65)
- New Battery ($110)
- Transmission Drain & Fill ($45-$180): Depending on the number of drain & fills you want to do
- AHC Fluid Replacement ($100): LX570 only
- KDSS Inspection & Lube ($20): LC200 only
- Brake Bleed ($??) - Suggested by @Sandroad
- Power Steering Flush ($??) - Suggested by @Sandroad
- Replace "heater T's" ($??)
- Replace Starter ($??) - Suggested by @krice118
- New gas cap ($20): Prevent warning lights for not sealing properly
- Fumoto F133N Oil Change Valve ($35): Easy Oil Changes
- LED Interior Lights ($25)
- LED Reverse Lights ($15)
- Venzo Metal Oil Filter Cap Replacement ($35)
- 3D Maxspider Floormats ($200)
- 8 x Spark Plug Seals ($55)
- Hikari LED Lights ($70-$90 per set)
- New TPMS sensors if you are getting new tires at any point ($150)
- Replace Skid Plate bolts if yours are rusted ($60)
- New wiper blades ($??) - Suggested by @ltsr
