Toyota Dealer March 2022 Major Discounts
Front Pass speaker is blown and has been for a year now. Do I replace with Toyota JBL or aftermarket? With discount, would be $200 for the single speaker
Props for the lead on parts. Could someone do a sanity check for me. Pretty sure I have it right but ... Four set brake pads are need all the way around. Also I need a couple of replacement blades (I have OEM blades assemblies) so just the blades. Thanks.
Air Filter 1780138030
Cabin Air Filter 8713976010
2 x Disc Brake Pad Set (Front) 0446560280
2 x Disc Brake Pad Set (Rear) 044 6660160
Tire Pressure Monitoring System Sensor 4260733012
Windshield Wiper Blade Left 85222YZZ11TM
Windshield Wiper Blade Right 85222YZZ12TM
You only need one set of each. Each set comes with four pads.
Where did you get those wiper blade part numbers? I have 85222-42110 and 85222-53071 for left and right respectively, and have confirmed fit with two sets since buying my cruiser. I suspect your YZZ numbers are the aftermarket sightline parts, being half the cost of the OEM part numbers.
Also if your fronts are done the rear probably is too: 85242-42030
That is correct.
With YZZ wipers, you can't use the cheap wiper inserts.
The YZZ were listed as well as the ones you note. I now see the difference in the two. Thanks.
Thanks for this.....picked up a radiator for $225 and a complete Timing Belt/rotating equipment replacement on my 4Runner V8. Every rotating bit on the engine is getting replaced.
Saved over $1,100
big kudos to you all, got a bunch of filters and replaced my headlights (2008) bc I'm tired of sanding and polishing the cracks and yellow UV damage out... can't beat $152 per headlight with no sales tax and free shipping
Wish I could replace mine on my 2010 LX. Still $450 even with a discount.
That was really tempting, but same thought. $900 is a bit steep just to avoid polishing them a few more times.
Which dealership did you get the headlights?
Edit: Nevermind you have an LC. I thought you were talking about LX headlights. They're $$$$ for the LX.
I would add some PPF to those new headlights to avoid replacing them again down the road or the ongoing restoration process.
Seems Xpel doesn't have a pre-cut headlight kit for the pre-facelift 200's.. This is what I purchased for 2016+ DIY.
I'm sure any PPF installer can easily take care of this for you.
Thanks guys...$450 down the "drain". I guess i'll count myself lucky that they tacked on a $300 freight charge for a new radiator, so i ended up dropping that from the cart. I'll just see if i can get my local dealer to match the price i guess.
Order it separately........that's what I did.
Count down clock is on.…..only a couple of hours left.
I also ordered rotors and pads as well filters.…over $500
I'm placing a second order just for filters. It hurt my brain to think about filters in the same box with rotors/calipers/pads :oops:
