Of course, have to otherwise the ride is complete sh**. I go down to about 18 PSI.Do you air down? And if yes to what psi?
Nitto and Toyo tires are made in the same factory. As I understand it, they even use the same carcass. The only difference between comparable load rated tires is the tread on the outside of the tire. So in this instance, the sidewall would likely be about the same or exactly the same.Ridge Grapplers>> ATIIIs.
Side note: I have had 6 sets of Toyo/Nitto tires. All the older ones, including my first set of Toyo MT's were made in Japan. The two most recent ATII and Trail Grapplers were made in the USA. I want to believe the ones made in Japan were of better quality but I can't prove it. =PNitto and Toyo tires are made in the same factory.
I put Nitto Terra Grapplers on mom's (H)eep WK2, while they've had lower mpg compared to the OE tires, we've been pleased with the results.Side note: I have had 6 sets of Toyo/Nitto tires. All the older ones, including my first set of Toyo MT's were made in Japan. The two most recent ATII and Trail Grapplers were made in the USA. I want to believe the ones made in Japan were of better quality but I can't prove it. =P
Anybody buy more recent LT tires from Toyo/Nitto that were made in Japan?
My toyos only balanced well the first time, refused to stay balanced after that. The side walls have much less rubber / protection on them than the ridge Grapplers do. The rubber on the sidewall of the ATIII is little more than decorative.Nitto and Toyo tires are made in the same factory. As I understand it, they even use the same carcass. The only difference between comparable load rated tires is the tread on the outside of the tire. So in this instance, the sidewall would likely be about the same or exactly the same.
The sidewalls on LT E rated Toyo’s is quite a bit beefier. More specifically the black wall made in Georgia versions. Almost all P rated versions of AT tires have milder sidewall patterns.My toyos only balanced well the first time, refused to stay balanced after that. The side walls have much less rubber / protection on them than the ridge Grapplers do. The rubber on the sidewall of the ATIII is little more than decorative.
View attachment 3145794View attachment 3145795
I've had E rated versions of both. I didn't find the toyos sidewall to be different than that picture. In fact, found a picture of mine.The sidewalls on LT E rated Toyo’s is quite a bit beefier. More specifically the black wall made in Georgia versions. Almost all P rated versions of AT tires have milder sidewall patterns.
| LT285/75R16 | 126/123R | E | OWL | 355670 | 7.5-8.0-9.5 | 56 | 16.5 | 33.1 | 11.3 | 3750/3415 | 80/80 | - | 628 |
| LT285/75R16 | 126/123R | E | BSW | 355680 | 7.5-8.0-9.5 | 59 | 16.5 | 32.8 | 11.3 | 3750/3415 | 80/80 | - | 633 |
Did you have discount tires replacement certificate on the tire when they replaced it for you?I would say it's probably best to replace the tire. We had a similar problem with the same brand/type of tire back in July of this year on a trip through Montana. Discount Tire took great care of us. View attachment 3761952
Absolutely!! I own multiple vehicles and all have certificates on them.Did you have discount tires replacement certificate on the tire when they replaced it for you?
