Towing with a 200-series Toyota Land Cruiser (13 Viewers)
Here is my 2016 with OPUS 4. Great set up and trailer can go anywhere the rig can.
Today I picked up the Lance 2185 we ordered a few weeks ago and towed it 90 miles home. Couldn’t be happier with the LC. Plenty of power. Stable. Zero sway, and it’ll get better when I get the WD hitch dialed in. I did most of the usual tow prep, plus a little. Upgraded rotors and pads (DBA). Redarc towpro Elite. Firestone airbags. I also added a cold air intake and ran 91 octane, and I swear it made a difference. Gibson exhaust is ordered but delayed. I had to eyeball the equalizer setup at Richards, (Lancaster CA Lance dealer) but I pulled into a scale on the way home and it was close enough for a quick trip. Rear axles was at max AWR. I’ll dial it in some more now that it’s home. Kids are stoked. I have TD 45mm adjustable and ran them on 7. Averaged 8.1 mpg for the trip.
Nice
If you don't intend to use the TV (seeing as how it's omitted in your photo) we added cabinet doors and converted ours to a pantry. With 3 kids there's never enough space for food and clothes on a multi-week trip.
Nice
That’s a great idea, and it may come to that, but I just opted out of the 12v $650 factory option and installed a $100 Roku TV myself. If it doesn’t hold up to the shaking and we don’t use it much, I’ll keep your idea in mind.
Just drove back from GA towing the 40, as expected the 200 had zero to little issues. I came back via 77 and 81 which takes you thru the mountains a bit. Might not be like some of the roads you guys pull out in mid west and west coast, but for the east coast it gets pretty steep. I did this to test the 200 and also avoid any potential traffic on 95.
On 85 I got 10mpg cruising around 70-75mph. On 77 and 81 I got around 9.5mpg cruising around 70mph. I wouldn't fight speed on the steeper hills, most of them I would drop down to around 60-65ish with no problems maintaining. There was one steep climb where I had to drop into 3rd and really get into it to keep the 200 around 55.
Verdict.. Jeez did it suck seeing around 180miles on the trip meter and gas light turn on! Also need to install the rear trim spacers I have sitting around.
Used this thread to set up my 08 for towing this summer. We towed a 21ft camper / toy hauler for the past 2 months - 6K miles or so around Idaho, Montana and in between Virginia. Used a Centerline WDH and was generally content with the towing. I didn't have the trailer on a scale, but I imagine it was close to 6K loaded and 800lbs or so on the tongue. Fuel mileage averaged around 8 across the trip.
I posted this on my personal blog at Towing with a 200-series Toyota Land Cruiser but wanted to share it here directly so it would be indexed.
I've read a number of different thoughts and opinions about towing with the 200-series Toyota Land Cruiser. One popular opinion which seems to come mostly from owners of full size diesel pickups, is that due to the relatively short 112" wheelbase, the Land Cruiser is a poor towing vehicle. After a few trips and tweaks to my setup, I can confidently say that with the proper setup, the Land Cruiser is actually a great towing vehicle.
Keep in mind everyone's trailer and towing setup will be a bit different, so rather than take my setup as the bible I recommend you try out your setup and make small adjustments until you're happy with it.
The Vehicles
My basic setup is a US-spec 2013 Toyota Land Cruiser with the 3UR-FE 5.7L V-8 engine, rated to tow 8,500 lbs with an 850 lb maximum tongue weight, and a 2005 Forest River Surveyor 235RS trailer which weighs about 5,000 lbs and has a roughly 600 lb tongue weight when loaded with all of our gear (except fresh water). Prior to the Land Cruiser we towed with a 2008 Acura MDX with 5,000 lb rated tow capacity, which definitely pushed the limits of that vehicle. Aside from the trailer, when camping we have 2 adults, 3 kids, a 75lb dog, a cooler full of food and ice, as well as clothing and other miscellaneous items in the vehicle (easily 650-700lbs).
Weight Distribution
One of the keys to the proper towing setup is a good weight distributing hitch with anti-sway setup. When I purchased the trailer I brought it home using a basic hitch and standard 2 5/16" hitch ball. When I got home I immediately ordered a Pro Series Weight Distribution Hitch with Sway Control for about $250 from eTrailer.com. (Note: Because I never expected my tongue weight to exceed 500 lbs I purchased the basic PS49901 model, with a 550lb limit. While I've considered upgrading the bars to allow me to shift more weight and better level the vehicle, the heavier bars tend to make the ride stiff and bouncy). When engaged, the weight distribution (WD) hitch and trunnion bars transfer a portion of the tongue weight off the rear axle onto the front axle of the vehicle. I once weighed the Acura at a truck stop with and without WD and the setup did shift about 80-100 lbs to the front axle depending on how many links on the chain were pulled up.
When I moved the Pro Series WD setup to the Land Cruiser, I discovered that the trailer was not level (nose-up by several inches). While most trailer hitches are level at 21-24", the Surveyor frame sits about 6" lower to the ground. Thus even at the lowest setting, the hitch ball was at least 4" too high. When combined with less tongue weight (one empty 30# propane cylinder and no bicycles stored in front), the trailer felt squirrel-y on the highway whenever there was a gust of wind. To get the trailer level when towing, I ended up purchasing a taller weight distribution hitch bar (shank) from Amazon for $75, which allowed me to drop the height of the hitch ball several inches lower. For my setup, I purchased a Curt 17123 (which is actually 12.25" tall) with the WD hitch mounted at the lowest setting makes the trailer almost perfectly level after my last modification.
Helper Air Bags
While the WD hitch does a solid job, I carry varying loads at times depending on whether we bring all 5 bicycles, how much propane is in the tanks, etc. I considered using a heavier duty WD setup, but the stiffer bars have a lower limit of 550 lbs which could present handling issues when running a lower tongue weight. In addition, it's recommended that 8 to 15% of your trailer weight be located on the tongue, and with a 5,000 lb trailer I was concerned about shifting too much weight off the tongue and onto the front axle as trailer sway, especially as caused by tractor trailers at highway speed, can be a serious problem. Rather than change to stiffer WD bars, I realized I needed to do something to better support or strengthen the rear suspension. That left me with two options:
  1. Upgrade the rear springs from standard to heavy duty (340lbf/in) or more. While this would limit compression (and thus the rear end sag) when towing, the stiffer springs would almost certainly make the rear end quite bouncy when unloaded. As the majority of our non-towing driving is on city streets loaded with potholes, I was afraid any upgrade would completely ruin the ride of the vehicle.
  2. Install a set of helper air bags inside the springs and inflate them when towing. This has the benefit of allowing adjusting the stiffness depending on the situation by adding or removing air from the bags.
I ended up opting for the helper air bags and purchased a Firestone 4164 air bag kit and a standard duty Air Lift 25804 air compressor from Amazon for under $250 and documented the installation here. I'll summarize that article with the following quote:
With 35psi in the bags, the Land Cruiser towed like a friggin’ champ. The ride was very smooth, and with the anti-sway bar installed I had no trouble running 70+mph on the highway. All in all I’m very pleased with the setup.
Sway Control
The Pro Series Weight Distribution Hitch I ordered comes with a friction anti-sway device (available separately for $40). It basically sandwiches a piece of metal between two other pieces which you compress by tightening a bolt on the device. If you're towing anything more than a pop-up at 45mph or higher, you really want one of these. The device takes less than 60 seconds to install or remove, but does a great job of limiting swaying in crosswinds or when passing tractor trailers on the highway.
Braking
The Land Cruiser comes with a trailer brake controller port, but if you're towing a trailer with a GVWR > 3,000lbs, you'll need to order and install a controller and wiring adapter. I purchased a Tekonsha Primus IQ a few years back for the Acura, so I just needed to order the Tekonsha Toyota Wiring Harness. Installation took about 30 minutes by following the Trailer Brake Controller Connector discussion over at iH8mud. I mounted mine at the bottom of the dash on the left side - out of the way, but requires me to lean forward to adjust it. My biggest complaint with the Primus IQ is that I feel like I'm always fiddling with it to get the braking proportion just right, which sometimes leaves me locking up the rear tires at low speeds.
Gauges
The last upgrade I made (and highly recommend) was to purchase an ELM327-compatible Wi-Fi OBDII reader ($15-20) and the EngineLink App for iOS ($6). When towing I insert the reader into the OBDII port and connect my iPhone to the CLKDevices WiFi name, then fire up EngineLink. Based on a number of other threads I read, I added two additional gauges in order to be able to monitor the automatic transmission pan and torque converter temperatures while towing:
  • Toyota A/T Pan Temp. PID 2182. Formula ((((A*256+B)*(7/100)-400)/10). Range -40 to 300. Units are F.
  • Toyota A/T TC Temp. PID 2182. Formula ((((C*256+D)*(7/100)-400)/10). Range -40 to 300. Units are F.
Transmission
Because the Land Cruiser is over-built, there's no need to add a separate auxiliary transmission cooler. However, when towing you should always put the vehicle into "Sport" mode by pushing the shift lever to the left. The "Sport" (or manual shift) mode limits the vehicle to no higher than 4th gear unless you manually select 5 or 6. This is Toyota's recommendation as well.
Based on my own monitoring of transmission temperatures, 4th gear (which is 1.000:1) minimized torque converter spin and significantly reduces heat. I wrote about my experience in this posting at iH8mud:
Limiting the vehicle to 4th gear I was cruising at 65-70 in mostly flat Illinois/Wisconsin (I-94) and ran around 2800RPMs +/-. I got ~10.5MPG at that speed (the instantaneous MPG reading from OBD2 was pretty steady between 10.2 and 10.8MPG). I tried running in 5th for a while but I found I had to lay into the gas pedal more to keep it at 65, so my gas mileage actually went down. Unless I was driving 55, using OD provided no MPG benefit.
I also watched the temps closely during the trip. Outside it was ~65F out. Intake temp was reading about ~90F (typical). My trailer was at the shop getting the bearings repacked so I drove about an hour to pick it up and then about an hour after I hitched up, thus I got some great comparison #'s:
  • Without a trailer running in top gear (6th) the transmission pan temp reached 195F (+/- 1F degree), and the torque converter was anywhere from 195F (when fully locked) to about 208F (for instance when accelerating from 60-70). The higher TC temp didn't affect the pan temp much. Once the TC locked up again at ~70MPH the temps would both stablilze around 195F again.
  • With the trailer running in 4th gear the pan temp stayed around 196F (+/-1F). Both the TC and the pan temp would read the same when cruising at 65MPH. About 2/3 of the way through the trip I tried running in 5th gear (first OD). The TC temp would climb (at one point it hit 213F) and the pan slowly climbed up to about 202F over the span of about 5 minutes before I put it back in 4th. At that point the temps slowly dropped down to 195F again. Also, I definitely noticed the weight of the trailer a LOT more when towing in 5th than in 4th.
In short, don't tow in overdrive - the gas mileage difference is small and OD generates heat in the transmission, especially if the ambient temps are warmer and/or you're pulling through hilly terrain. Yes if you're pulling a 2000# 4x5x8 uhaul trailer you can probably run in 5th or 6th without any damage, but if you're pulling a smaller trailer running in your 1:1 gear (6th in your case) will have less impact on your MPG than it does for me, so the $ savings is minimal.
I had a second opportunity to confirm my temps this weekend when the outside ambient temperature was 86F and got nearly identical results. At 70mph on the highway the engine temp read 194F and both the pan and torque converter on the automatic transmission read 198.5F.
I understand the "A/T Temp" warning light will come on at 302F, though I hope to never confirm that.
Last Thoughts
With the proper setup (weight distribution, anti-sway, and upgraded rear springs or helper air bags), the 200-series Land Cruiser has no trouble towing a 24' travel trailer weighing 5,000 lbs. We don't intend to upgrade our trailer, but if we did I wouldn't hesitate to go up to ~26' and 6,000 lbs. While you should always follow manufacturer recommendations, I felt very comfortable cruising at 70mph and am looking forward to taking a much longer trip to Mt. Rushmore later this summer. As I said in the air bag installation posting, the Land Cruiser towed like a friggin’ champ.
hi, I have a similar setup as you had on this. Having done this, was there anything you would have changed or were you pleased throughout?
If I was doing it again I'd get OME 2721 progressive coils and use those in the rear, instead of the single-rate standard Tough Dog coil. Or if you know you'll have extra weight I'd go with 2722s. The standard coil is fine if you have a small trailer but with a family and gear I'm at GWVR before adding the trailer, and I've found I end up adding so much trailer TW that the airbags are barely a supplement.
With my newer Lance 2185 trailer (similar length but 1000# more weight) I gave the ProSeries hitch away and bought a higher rated Blue Ox. I would highly recommend that over the ProSeries. The PS did OK, but the BO is much better at controlling sway without creaking and groaning every time you make a turn.
I have pulled a Lance 2285 and now a 1995 and I have the 2721s. I would say it was by design but @Markuson happened to be at Slee having his rig built and gave me the 2721s that he had been using. They ended up being a great fit. A bit less stiff when I am not towing. But they firm up nicely as the trailer settles onto them. Very pleased I went that route.
Cool, that’s useful info
Yeah they are 270/340 pounds per inch progressive. The TD standard are 240#. Hence my hunch they would be better. If you’re towing I would definitely opt for the 2721 over the 2722 (which is fixed at 270#/in).
I need to get those springs for my 200. @linuxgod I'm glad you like the blue ox. I'm running the 1k bars on my setup and have been very happy. I've used the friction bar setups and have not been happy with them. Way too noisy and nerve wracking to use.
I've found a breaker bar with a socket is a must have with the BO instead of the tool they provide.
BTW, Geoff, I was never able to get the Redarc working. They replaced the unit which I received and installed about a week ago. I've towed with it three times since then and no sign of the issues I had with the original. Works great. Thank you for trying to help me through the diagnosis! I'm very pleased it worked out. I really didn't want to go back to having the Tekonsha brick in my way again.
I still use their tool, though it's apparently softer than the cradles and seems to be rounding out on me. You do need to jack up the tongue while attached to take a lot of stress off the bars, otherwise they'll whack you when you try to release...
Cool, I'm keeping my fingers crossed for you. The Redarc performance is similar to the Tekonsha but being able to mount the knob somewhere close and the larger unit itself remotely under the dash is really nice. I will say the memory on the Redarc is more tempermental in my experience... it'll need to recalibrate any time you change (or drain) the battery. But being able to reach the knob while driving without sticking my face into the steering wheel to reach down under the dash makes it worthwhile
With my "new to me" 2018 LC, it came with the Tough Dog suspension. I still have not connected up to my Lance 2375 yet, as I had to modify the Slee rear bumper swing outs to clear my trailer's jack. (Basically, re-installed the OEM spare tire carrier and moved the tire down there, plus I pulled the jerry can basket off but have the ability to put them back when I use the truck without the trailer). How do I determine what my coils are on this truck or is it just going to be "try it and see what happens"? It does have the adjustable shocks installed.
Thanks!
Thanks. So far so good. And, yes, using the Redarc with my ProPropride hitch or with different trailers (I'm towing utility trailers loaded with used furniture for a local charity as well as my Lance) all I need to do is increase the dial a bit to "dial it in". Works great. As for needing to recalibrate when I disconnect the battery. I have a LOT of experience with that! Until they replaced the unit I had the only remedy was to disconnect my battery (negative terminal) and then reconnect. Apparently the unit was failing or "hanging" during the startup process. So each time I had to recalibrate - as well as reset some settings on my LC (temperature setting when in Auto, restart the cool box, etc.) and remember that the first attempt to start the LC after disconnecting the battery would fail and I would have to start it again. Had to do this about 10-15 times this summer while camping. (It was suggested on a battery thread that you can simply start up accessories only and after that is done start the engine but before I had time to test that the replacement unit came in.)
Good info. Could I also ask you regarding the airbag weight distribution hitch setup. Did you set the airbags up before or after setting up the weight distribution hitch? My thought is doing the airbags before the WDH, but curious what you did.
Thanks
Chris
Thanks
Chris
I believe the way you're supposed to do it is to put the trailer on the hitch, inflate the air bags, and then set up WD.
Practically I just hitch up and then inflate to 30psi. Why? Because I've found in my setup WD removes a few PSI but it's not significant (e.g. 27psi vs 30psi) and doing so is faster.
About to pull trigger on a new 2021 LC. Trailer is a 2015 Airstream 23D (narrow body) that scales 6,069 pounds with a 969
About to pull trigger on a 2021 LC. Trailer we will pull is a 2015 Airstream 23D (narrow body) that scales 6,063 pounds camping ready and has a 928 pound tongue weight. We use a Hensley Arrow weight distribution hitch, Prior tow vehicle was a 2007 Mercedes ML320 CDI turbo diesel that was wonderful. Impending third major engine expense reoccurrence at 205,000 miles was the end of the Mercedes for us. Still have the big Ram 2500HD Cummins towing the 31' Classic and as well as the 23D. So thus the interest in a smaller tow vehicle that will last.
From reading about ten pages of this read, I see the LC should handle this with aplomb. But I wonder if it will do so stock? We towed the 23D at 55 mph with the Mercedes as that was the sweet spot for the engine. We are not in a rush!
928# is too much weight for the tongue on a stock vehicle. The truck is rated at 850# max.
It is possible to tow 900#+ with a stock setup, and people do it, but you are outside the Toyota specs (and IMO with stock rear springs it's just too much weight)
