There are individuals, including Andy at Can-Am Canada, whom are respected subject matter experts in the RV industry with decades of direct experience setting up travel trailers/AS to passenger cars and trucks, whom don't believe in airbags or automatic leveling. Or at least firmly believe they are a liability with how they are misused. They would say that vehicle attitude is a function of properly dialed in weight distribution alone. If the tow vehicle is not level, then there is not enough WD dialed in. http://www.inlandrv.com/articles/towing_myths.pdf
To me, airbag are more about increasing spring rate for dynamic load handling on the road, rather than statically leveling the tow vehicle. Leveling should still be done via WD adjustment, because that directly transfers load to the front axle, and the vehicle attitude will reflect when this is adequately done.
I've seen some argue that a properly setup bag should see PSI in the lower pressure range, rather than the upper range. That is, rely more on WD, and less on air bags.
I would be VERY weary of the T-fitting and would highly recommend against linking the bags, as it can create dangerous handling behavior. What this does is create a seesaw, if you will, between the two wheels at the rear axle. Any side to side load imbalances, or turning, will cause the load support (i.e.) air to go to the other side. So instead of two independent bags that stably support the car at each side, a linked bag gives no lateral support as the air will simply "escape" to the other side. Imagine how this imbalanced support may work under emergency handling maneuvers.
One note is that the Firestone kit comes with two separate schraeder valves (one per bag). I bought a small compressor for $100 and installed it where my jack was. Because that only has one output line, I bought a T fitting (https://www.amazon.com/gp/product/B001F532PY/?tag=ihco-20) to tie them together. If you search around online there are mixed feeling about linking both air bags to one compressor (some people prefer it because it ensures the pressure is balanced, some dislike it because it's harder to isolate a leak or might result in odd handling as air transfers between bags. Personally I've found it takes 30 seconds or so to deflate these so I don't think the small tube lets a significant amount of air pressure move between either bag while bouncing around).
