Question: The measurement from the top of fender opening to center of Hub is 21-3/4". Is that alot / too much?
thanks
FWIW: I was getting bump steer that actually emanated from the rear. It was especially noticeable when I drove over speed bumps. I installed Slee's adjustable pan-hard rod and eliminated 90% of the problem. I imagine I could get it back to stock if I relocated one of the pan-hard mounts so that the rod sits more or less horizontal ala stock lift.
Don't know if that is what you are feeling with your "bump" steer or not...
^^^been doing a lot of research here lately on this very topic. Best I can tell is ideal rake (difference in height from rear to front) is 1 inch. I was running level for a few months after my lift install and noticed the vehicle tracking towards any uneven surface on the road. Just didn't feel right, so I lowered the front to allow for a 1 inch rake. Haven't driven yet but looking forward to see if there is any improvement.
I'm 21 5/8" hub center to fender on my 100... I have about 2.5* front caster and I'm using TC upper control arms. About 70mm droop. If you cannot achieve something in that caster range or better you are in for torque steer. The factory upper arms won't let you get back to that caster if the lift is too large. The rake is really academic - rear springs play a big part of this visual equation... put 863's on the back in an empty truck and you're never getting 1". It will be ass up. You need to match your rear to the load you are running in conjunction with the spring height.
RobRed, how did you measure your caster? Didn't know you could...![]()
