Torque Converter Lock-up Mods to the A442F 80 Series Trans
Has anyone tried to modifiy the signal to the torque converter lockup solenoid? I found one reference to this with a guy in AUS, that has lower TcFD gears and a torque converter lock-up switch, but neither appears installed.
Looking at the new FJ Flex Lockup Torque Converter and other marques newer truck "downhill descent mode" vs the factory FSM on the 442, this sure appears to be a modification that might be beneficial during downhill descents and possibly rock crawling. 1st gear has no lockup function in the factory 80 trans ECU, which means maximum slippage (heat) of the Torque Converter during downhill approaches. It appears that the modification signal to the TCLO solenoid is fairly straight forward.
The stock 80 currently unlocks the torque converter if any of the three conditions are present: CC drops below 2mph from set speed, IDL switch activation on T-body, or brake light switch activated. Sure seems to me that if you left the brake signal disengage to prevent engine stall, you would have direct drive (engine>gears) lockup torque converter for hill descents. On throttle appears to be a bit trickier, but the signal values in the FSM could give partial lockup lockup conditions for climbing based on varying load parameters. Just like the new FJ, hopefully just simpler and less problematic.
Anyone tried a lockup switch on the torque converter?
Scott J
93 FZJ80 Supercharged
Scott J
