Todays wrenching
I think this says it all
Probably hurts some until you've had a few, but you could relieve the pain some by entertaining folks. Make a thumb puppet to entertain the kids. Paint a face on it with a magic marker. That's what I'd do. :hillbilly:
wilma lives!!!! finished up the v8 swap this evening and drove her home. very very satisfied so far.
will get some this afternoon with my good camera (no crappy iphone pics :)
some progress this weekend:
New meats
i posted this thread in the 40 section..
CAN'T get the 40 into GEAR.. So here's the whole story.. i have a '74 fj40 with stock 4 speed tranny and transfer case.
When i parked my rig where it sits now 3 months ago it was in 2 wheel drive.. the front hubs were locked because it was snowing and i had been using 2 and 4 that day.. it sat there for about a month.
Next time i went to move it a month later.. i started it fine went to go and spun the tires because of the snow so needed to put it in 4wd to get out.. would not engage into 4h or 4low or into 2wd from that moment on.. no grinding or bad noises or anything.. seems the transfer case is stuck in neutral or something.
i tried rolling the vehicle back and forth while shifting as sometimes that helps and nothing will catch.
any insight?
took some pics of hte v8 installed. I also found a place for all those stickers your want to put on your truck but you don't really want to put on your truck.
it does I got a ton of clean up work to do. like the wiring needs some attention and I need to plumb up my heater again. but it literally runs like a new car start up is instant I am in love with the automatic choke. :)
any insight?
In attempting to shift between 2H, 4H, and 4L, does the lever move normally or is it stuck?
Did you check to see if your slave cylinder is leaking? Do you have fluid in the reservoir? You may need to adjust the slave cylinder push rod if you have fluid.
any insight?
You get one of those with the Dashman Dash Box to cut the spot welds that hold the upper dash pad frame to the cowl... definitely a good thing to have around...
