Tire Pressure recommendation (4 Viewers)
@gaijin May I please have the RCTIP for the Michelin LTX AT/2 E in 285/65/18? 2015 LC on stock wheels.
Thanks!!
Thanks!!
Sure!
The RCTIP for those Michelin LTX A/T2 tires in size LT285/65R18/E 125/122R on your 2015 LC200 is 42psi F/R.
HTH
Hey @gaijin - I just put on some Falken AT3W 295/70/18 on my LX570 on Tundra wheels. Would you be able to provide the RCTIP? Thanks a bunch!
Sure!
I assume you are asking about the LT295/70R18 129/126R Load Range E tires, right?
The RCTIP for those LT295/70R18 tires on your LX570 is 35psi F/R.
HTH
gaijin, could you please help with the RCTIP for 285/75R17 121S E1 Cooper Discoverer AT3 XLT on '13 LX? Thanks
Assuming you mean the LT285/75R17 121/118S Load Range E tires, the RCTIP for those on your LX570 is 35psi F/R.
HTH
@gaijin
Many many thanks in advance for you help as you appear to be the guru in the matter. I am looking for proper RCTIP to avoid irregular tire wear.
2015 Land Cruiser
Toyo R/T in LT285/75R17
Load Rating E
121/118Q
Product Code 353480
@gaijin
2015 Land Cruiser
Load Rating E
121/118Q
Product Code 353480
Glad to help 👍
The RCTIP for those LT285/75R17 tires on your LC200 is 37psi F/R.
HTH
Hey gaijin,
How about Toyo open country AT3 in LT285/70r17 116/113Q “C” load on a LandCruiser?
I saw mention earlier of all LT285/70R17 on a cruiser using 40psi but wanted to make sure. Plus get a searchable post in for this tire on a cruiser. Plenty of LX posts so far.
Hey gaijin,
Sure!
Yes, ALL LT285/70R17 tires on a LC200 are the same 40psi RCTIP - it's even in my sig! It's also in the original Toyota data sheet for the RW wheels (Toyota Installation Sheet for 17" TRD Alloy Wheels).
For the record:
The RCTIP for those LT285/70R17 tires on your LC200 is 40psi F/R.
HTH
Searched this thread and not one post for 275/55R20 Toyo Open Country AT II's on an LX570. Looking to go to 17's or 18's but for now, this is what it came with.
Thanks ahead of time!
The Toyo Open Country A/T II in that size is an ISO-Metric XL tire with a 117 Load Index. Therefore:
The RCTIP (Recommended Cold Tire Inflation Pressure) for that 275/55R20 117T XL tire on your LX570 is 33psi F/R.
HTH
RCTIP Table for Land Cruiser and LX 570:
Maybe we can save some people some time. EDIT: This all seems kind of spammy now (4 posts), so if someone wants me to delete it, I will. Another option is if I left out all the tire data it might all fit in one post.
Here's a table of all possibly relevant tire sizes to the 200 Series. I filtered out all tires less than 17" and skinnier than 10.86" (265). ISO - Metric system doesn't care about size, so you match up the rating. I only have the recommended pressures for the more common USA Land Cruiser and LX 570. It's trivial to add any columns for different OEM RCTIPs if anyone wants one added. The quoted sizes are calculated from the standard and not referenced to any specific tire brand/model.
(it wasn't trivial getting the data from all the tables into a uniform excel sheet, so it's possible I may have some mistakes in that. Feel free to comment if you see a mistake. I've spot checked the data and don't see any glaring errors.)
LT Sizes
RCTIP
LandcruiserLX 570
Tire SizeP285/60R18 @ 33PSIP285/50R20 @ 33PSITypeWheel SizeDiameter (in)Sidewall (in)Width (in)Load OptionsMin LoadMax Load
LT265/65R1751 PSI45 PSILT
17​
30.56​
6.78​
10.86​
(D)116-65PSI / (E)120-80PSI
1765​
3085​
LT265/70R1746 PSI41 PSILT
17​
31.61​
7.3​
10.86​
(C)112-50PSI / (D)118-65PSI / (E)121-80PSI
1890​
3195​
LT275/65R1747 PSI42 PSILT
17​
31.07​
7.04​
11.27​
1870​
3195​
LT275/70R1743 PSI38 PSILT
17​
32.16​
7.58​
11.27​
(C)114-50PSI(E)121-80PSI
2000​
3195​
LT275/80R1738 PSI35 PSILT
17​
34.32​
8.66​
11.27​
(D)121-65PSI / (E)121-80PSI
2205​
3195​
LT285/60R1749 PSI44 PSILT
17​
30.46​
6.73​
11.68​
(C)110-50PSI
1820​
2335​
LT285/65R1744 PSI39 PSILT
17​
31.59​
7.29​
11.68​
(E)121-80PSI
1965​
3195​
LT285/70R1740 PSI35 PSILT
17​
32.71​
7.85​
11.68​
(C)116-50PSI / (D)121-65PSI / (E)121-80PSI
2105​
3195​
LT285/75R1737 PSI35 PSILT
17​
33.83​
8.42​
11.68​
(C)117-50PSI / (D)121-65PSI / (E)121-80PSI
2215​
3195​
LT295/70R1737 PSI35 PSILT
17​
33.26​
8.13​
12.09​
(E)121-80PSI
2215​
3195​
LT295/75R1735 PSI35 PSILT
17​
34.42​
8.71​
12.09​
(D)121-65PSI
2320​
3195​
LT305/65R1738 PSI35 PSILT
17​
32.61​
7.81​
12.5​
(E)121-65PSI / (F)121-80PSI
2205​
3195​
LT305/70R1735 PSI35 PSILT
17​
33.81​
8.41​
12.5​
(D)119-50PSI / (E)121-65PSI
2405​
3195​
LT315/70R1735 PSI35 PSILT
17​
34.36​
8.68​
12.91​
(C)113-35PSI / (D)121-50PSI / (E)121-65PSI
2535​
3195​
LT325/70R1735 PSI35 PSILT
17​
34.91​
8.96​
13.32​
(D)121-50PSI
2600​
3195​
LT345/55R1736 PSI35 PSILT
17​
31.94​
7.47​
14.14​
(D)117-50PSI
2270​
2835​
LT355/70R1735 PSI35 PSILT
17​
36.57​
9.78​
14.55​
(D)121-50PSI
3000​
3195​
LT265/60R1854 PSI48 PSILT
18​
30.52​
6.26​
10.86​
(D)114-65PSI / (E)119-80PSI
1695​
3000​
LT265/65R1848 PSI43 PSILT
18​
31.56​
6.78​
10.86​
(D)117-65PSI / (E)122-80PSI
1830​
3305​
LT265/70R1844 PSI39 PSILT
18​
32.61​
7.3​
10.86​
(E)124-80PSI
1960​
3525​
LT275/65R1845 PSI40 PSILT
18​
32.07​
7.04​
11.27​
(C)113-50PSI / (D)119-65PSI / (E)123-80PSI
1940​
3415​
LT275/70R1841 PSI36 PSILT
18​
33.16​
7.58​
11.27​
(C)115-50PSI / (D)121-65PSI / (E)125-80PSI / (F)128-95PSI
2070​
3970​
LT275/80R1835 PSI35 PSILT
18​
35.32​
8.66​
11.27​
(E)128-80PSI
2353​
3970​
LT285/60R1846 PSI41 PSILT
18​
31.46​
6.73​
11.68​
(D)118-65PSI / (E)122-80PSI
1885​
3305​
LT285/65R1842 PSI37 PSILT
18​
32.59​
7.29​
11.68​
2035​
3640​
LT285/70R1838 PSI35 PSILT
18​
33.71​
7.85​
11.68​
(E)127-80PSI
2180​
3860​
LT285/75R1835 PSI35 PSILT
18​
34.83​
8.42​
11.68​
(E)129-80PSI
2290​
4080​
LT295/65R1839 PSI35 PSILT
18​
33.1​
7.55​
12.09​
(E)127-80PSI
2150​
3860​
LT295/70R1835 PSI35 PSILT
18​
34.26​
8.13​
12.09​
(C)119-50PSI(E)129-80PSI
2295​
4080​
LT305/60R1840 PSI35 PSILT
18​
32.41​
7.2​
12.5​
(E)121-65PSI / (F)126-80PSI
2150​
3750​
LT305/65R1835 PSI35 PSILT
18​
33.61​
7.81​
12.5​
(E)124-65PSI / (F)128-80PSI
2335​
3970​
LT305/70R1835 PSI35 PSILT
18​
34.81​
8.41​
12.5​
(E)126-65PSI / (E)128-80PSI
2470​
3970​
LT305/75R1835 PSI35 PSILT
18​
36.01​
9.01​
12.5​
(D)122-50PSI / (E)128-65PSI
2600​
3970​
LT315/70R1835 PSI35 PSILT
18​
35.36​
8.68​
12.91​
(E)127-65PSI
2600​
3860​
LT325/60R1835 PSI35 PSILT
18​
33.35​
7.68​
13.32​
(E)124-65PSI
2335​
3525​
LT325/65R1835 PSI35 PSILT
18​
34.63​
8.32​
13.32​
(D)121-50PSI / (E)127-65PSI
2535​
3860​
LT345/60R1835 PSI35 PSILT
18​
34.3​
8.15​
14.14​
(D)121-50PSI
2535​
3195​
LT355/65R1835 PSI35 PSILT
18​
36.17​
9.08​
14.55​
(E)128-65PSI
2910​
3970​
LT375/50R1835 PSI35 PSILT
18​
32.76​
7.38​
15.37​
(E)124-65PSI
2335​
3525​
LT375/60R1835 PSI35 PSILT
18​
35.72​
8.86​
15.37​
(D)125-50PSI
2910​
3640​
LT395/65R1835 PSI35 PSILT
18​
38.22​
10.11​
16.19​
(C)123-35PSI
3415​
3415​
LT265/50R2064 PSI57 PSILT
20​
30.43​
5.22​
10.86​
(E)115-80PSI
1520​
2680​
LT265/60R2049 PSI43 PSILT
20​
32.52​
6.26​
10.86​
(E)121-80PSI
1825​
3195​
LT275/55R2051 PSI46 PSILT
20​
31.91​
5.95​
11.27​
(D)115-65PSI
1750​
2680​
LT275/60R2045 PSI40 PSILT
20​
32.99​
6.5​
11.27​
(D)123-65PSI / (E)123-80PSI
1920​
3415​
LT275/65R2041 PSI36 PSILT
20​
34.07​
7.04​
11.27​
(E)126-80PSI
2080​
3750​
LT285/50R2055 PSI49 PSILT
20​
31.22​
5.61​
11.68​
(E)119-80PSI
1665​
3000​
LT285/55R2048 PSI43 PSILT
20​
32.34​
6.17​
11.68​
1850​
3305​
LT285/60R2042 PSI38 PSILT
20​
33.46​
6.73​
11.68​
(E)125-80PSI
2020​
3640​
LT285/65R2038 PSI35 PSILT
20​
34.59​
7.29​
11.68​
(E)127-80PSI
2180​
3860​
LT295/55R2045 PSI40 PSILT
20​
32.78​
6.39​
12.09​
(E)123-80PSI
1935​
3415​
LT295/60R2039 PSI35 PSILT
20​
33.94​
6.97​
12.09​
(E)126-80PSI
2125​
3750​
LT295/65R2035 PSI35 PSILT
20​
35.1​
7.55​
12.09​
(E)129-80PSI
2300​
4080​
LT305/50R2050 PSI44 PSILT
20​
32.01​
6​
12.5​
(E)117-65PSI
1875​
2835​
LT305/55R2042 PSI36 PSILT
20​
33.21​
6.6​
12.5​
(E)121-65PSI / (F)125-80PSI
2095​
3640​
LT305/60R2036 PSI35 PSILT
20​
34.41​
7.2​
12.5​
(D)118-50PSI / (E)123-65PSI
2270​
3415​
LT315/50R2045 PSI40 PSILT
20​
32.4​
6.2​
12.91​
(D)112-50PSI
1985​
2470​
LT315/60R2035 PSI35 PSILT
20​
34.88​
7.44​
12.91​
(E)125-65PSI
2405​
3640​
LT315/70R2035 PSI35 PSILT
20​
37.36​
8.68​
12.91​
(D)124-50PSI / (E)130-65PSI
2755​
4190​
LT325/50R2043 PSI38 PSILT
20​
32.8​
6.4​
13.32​
(E)120-65PSI
2040​
3085​
LT325/60R2035 PSI35 PSILT
20​
35.35​
7.68​
13.32​
(D)121-50PSI / (E)126-65PSI
2535​
3750​
LT325/75R2035 PSI35 PSILT
20​
39.19​
9.6​
13.32​
(D)127-50PSI
3085​
3860​
LT335/55R2035 PSI35 PSILT
20​
34.51​
7.25​
13.73​
(D)119-50PSI / (E)125-65PSI
2405​
3640​
LT355/60R2035 PSI35 PSILT
20​
36.77​
8.39​
14.55​
(D)125-50PSI / (E)128-65PSI
3640​
6902​
Had to break it up into posts due to character limit.
Floatation:
RCTIP
LandcruiserLX 570
35x10.50R17LT37 PSI33 PSIFloatation
17​
35​
9​
10.5​
1760​
3195​
35x11.50R17LT34 PSI31 PSIFloatation
17​
35​
9​
11.5​
(C)118-50PSI(E)121-80PSI
1830​
3195​
33x12.50R17LT41 PSI37 PSIFloatation
17​
33​
8​
12.5​
(C)105-35PSI / (D)114-50PSI / (E)120-65PSI / (F)121-80PSI
1610​
3195​
35x12.50R17LT33 PSI30 PSIFloatation
17​
35​
9​
12.5​
(C)111-35PSI / (D)119-50PSI / (E)121-65PSI
1875​
3195​
37x12.50R17LT28 PSI25 PSIFloatation
17​
37​
10​
12.5​
(C)116-35PSI(F)121-80PSI
2150​
3195​
17​
37​
10​
12.5​
(C)116-35PSI / (D)124-50PSI
2150​
3525​
37x13.50R17LT27 PSI25 PSIFloatation
17​
37​
10​
13.5​
2205​
3195​
38x13.50R17LT25 PSI25 PSIFloatation
17​
38​
10.5​
13.5​
(C)119-35PSI
2405​
3000​
39x13.50R17LT25 PSI25 PSIFloatation
17​
39​
11​
13.5​
(C)121-35PSI
2535​
3195​
40x13.50R17LT25 PSI25 PSIFloatation
17​
40​
11.5​
13.5​
(C)121-35PSI
2680​
3195​
36x14.50R17LT28 PSI25 PSIFloatation
17​
36​
9.5​
14.5​
(D)121-50PSI
2150​
3195​
38x14.50R17LT25 PSI25 PSIFloatation
17​
38​
10.5​
14.5​
(D)121-50PSI
2470​
3195​
40x14.50R17LT25 PSI25 PSIFloatation
17​
40​
11.5​
14.5​
(C)121-35PSI
2755​
3195​
42x14.50R17LT25 PSI25 PSIFloatation
17​
42​
12.5​
14.5​
(C)121-35PSI
3085​
3195​
38x15.50R17LT25 PSI25 PSIFloatation
17​
38​
10.5​
15.5​
(C)121-35PSI
2535​
3195​
33x11.50R18LT46 PSI41 PSIFloatation
18​
33​
7.5​
11.5​
(E)122-80PSI
1505​
3305​
35x11.50R18LT37 PSI33 PSIFloatation
18​
35​
8.5​
11.5​
(E)127-80PSI
1765​
3860​
37x11.50R18LT30 PSI27 PSIFloatation
18​
37​
9.5​
11.5​
(E)128-80PSI
2030​
3970​
33x12.50R18LT44 PSI39 PSIFloatation
18​
33​
7.5​
12.5​
(E)118-65PSI / (F)122-80PSI
1565​
3305​
34x12.50R18LT39 PSI35 PSIFloatation
18​
34​
8​
12.5​
(E)121-65PSI
1710​
3195​
35x12.50R18LT35 PSI31 PSIFloatation
18​
35​
8.5​
12.5​
(D)118-50PSI / (E)123-65PSI / (F)128-80PSI
1820​
3970​
37x12.50R18LT29 PSI26 PSIFloatation
18​
37​
9.5​
12.5​
(C)115-35PSI / (D)123-50PSI / (E)128-65PSI
2095​
3970​
35x13.50R18LT33 PSI30 PSIFloatation
18​
35​
8.5​
13.5​
(D)119-50PSI
1875​
3000​
36x13.50R18LT30 PSI27 PSIFloatation
18​
36​
9​
13.5​
(D)121-50PSI
2040​
3195​
37x13.50R18LT28 PSI25 PSIFloatation
18​
37​
9.5​
13.5​
(D)124-50PSI
2150​
3525​
36x14.50R18LT29 PSI26 PSIFloatation
18​
36​
9​
14.5​
(D)122-50PSI
2095​
3305​
38x14.50R18LT25 PSI25 PSIFloatation
18​
38​
10​
14.5​
(D)127-50PSI
2405​
3860​
40x14.50R18LT25 PSI25 PSIFloatation
18​
40​
11​
14.5​
(C)123-35PSI
2680​
3415​
38x15.50R18LT25 PSI25 PSIFloatation
18​
38​
10​
15.5​
(D)128-50PSI
2470​
3970​
33x11.50R20LT55 PSI49 PSIFloatation
20​
33​
6.5​
11.5​
(E)118-80PSI
1345​
2910​
34x11.50R20LT47 PSI42 PSIFloatation
20​
34​
7​
11.5​
(E)121-80PSI
1480​
3195​
35x11.50R20LT42 PSI37 PSIFloatation
20​
35​
7.5​
11.5​
(E)124-80PSI
1615​
3525​
37x11.50R20LT33 PSI30 PSIFloatation
20​
37​
8.5​
11.5​
(E)128-80PSI
1890​
3970​
33x12.50R20LT53 PSI47 PSIFloatation
20​
33​
6.5​
12.5​
(E)114-65PSI / (F)119-80PSI
1390​
3000​
35x12.50R20LT40 PSI36 PSIFloatation
20​
35​
7.5​
12.5​
1655​
3640​
37x12.50R20LT32 PSI28 PSIFloatation
20​
37​
8.5​
12.5​
(D)120-50PSI / (E)126-65PSI / (F)128-80PSI
1930​
3970​
33x13.50R20LT51 PSI45 PSIFloatation
20​
33​
6.5​
13.5​
(F)120-80PSI
1435​
3085​
35x13.50R20LT39 PSI34 PSIFloatation
20​
35​
7.5​
13.5​
1710​
3750​
37x13.50R20LT30 PSI27 PSIFloatation
20​
37​
8.5​
13.5​
1985​
3860​
38x13.50R20LT28 PSI25 PSIFloatation
20​
38​
9​
13.5​
(E)128-65PSI
2150​
3970​
40x13.50R20LT25 PSI25 PSIFloatation
20​
40​
10​
13.5​
(D)128-50PSI / (E)128-65PSI
2470​
3970​
42x13.50R20LT25 PSI25 PSIFloatation
20​
42​
11​
13.5​
(C)124-35PSI
2755​
3525​
37x14.50R20LT29 PSI27 PSIFloatation
20​
37​
8.5​
14.5​
(E)128-65PSI
2040​
3970​
38x14.50R20LT27 PSI25 PSIFloatation
20​
38​
9​
14.5​
(D)124-50PSI
2205​
3525​
40x14.50R20LT25 PSI25 PSIFloatation
20​
40​
10​
14.5​
(C)121-35PSI
2535​
3195​
42x14.50R20LT25 PSI25 PSIFloatation
20​
42​
11​
14.5​
(C)125-35PSI
2835​
3640​
36x15.50R20LT32 PSI29 PSIFloatation
20​
36​
8​
15.5​
(E)126-65PSI
1930​
3750​
38x15.50R20LT26 PSI25 PSIFloatation
20​
38​
9​
15.5​
(D)125-50PSI
2270​
3640​
40x15.50R20LT25 PSI25 PSIFloatation
20​
40​
10​
15.5​
(D)128-50PSI
2600​
3970​
P-Metric (eliminated a few more sizes that aren't applicable due to non compliant load rating to save characters)
RCTIP
LandcruiserLX 570
P265/65R17Tire Not Applicable35 PSIP-Metric
17​
30.56​
6.78​
10.86​
110
2039​
2337​
P265/70R1735 PSI29 PSIP-Metric
17​
31.61​
7.3​
10.86​
113
2194​
2535​
P275/60R17Tire Not Applicable35 PSIP-Metric
17​
29.99​
6.5​
11.27​
110
2017​
2337​
P275/65R1735 PSI30 PSIP-Metric
17​
31.07​
7.04​
11.27​
113
2172​
2535​
P285/65R1731 PSI26 PSIP-Metric
17​
31.59​
7.29​
11.68​
115
2315​
2679​
P285/70R1727 PSI26 PSIP-Metric
17​
32.71​
7.85​
11.68​
117
2480​
2833​
P305/60R1732 PSI28 PSIP-Metric
17​
31.41​
7.2​
12.5​
116
2227​
2756​
P265/65R18Tire Not Applicable32 PSIP-Metric
18​
31.56​
6.78​
10.86​
112
2116​
2469​
P265/70R1832 PSI27 PSIP-Metric
18​
32.61​
7.3​
10.86​
114
2271​
2601​
P275/60R18Tire Not Applicable32 PSIP-Metric
18​
30.99​
6.5​
11.27​
111
2094​
2403​
P275/65R1833 PSI28 PSIP-Metric
18​
32.07​
7.04​
11.27​
114
2260​
2601​
P275/70R1832 PSI28 PSIP-Metric
18​
33.16​
7.58​
11.27​
116
2227​
2756​
P285/55R18Tire Not Applicable33 PSIP-Metric
18​
30.34​
6.17​
11.68​
111
2072​
2403​
P285/60R1833 PSI29 PSIP-Metric
18​
31.46​
6.73​
11.68​
114
2227​
2601​
P305/45R18Tire Not Applicable36 PSIP-Metric
18​
28.81​
5.4​
12.5​
110
1885​
2337​
P265/60R20Tire Not Applicable33 PSIP-Metric
20​
32.52​
6.26​
10.86​
112
1995​
2469​
P275/55R20Tire Not Applicable32 PSIP-Metric
20​
31.91​
5.95​
11.27​
111
2094​
2403​
P275/60R2033 PSI28 PSIP-Metric
20​
32.99​
6.5​
11.27​
114
2260​
2601​
P285/50R20Tire Not Applicable33 PSIP-Metric
20​
31.22​
5.61​
11.68​
111
2061​
2403​
P285/55R2035 PSI31 PSIP-Metric
20​
32.34​
6.17​
11.68​
114(116)
2105​
2756​
P295/45R2039 PSI35 PSIP-Metric
20​
30.45​
5.23​
12.09​
110(114)
1938​
2601​
P305/55R2032 PSI28 PSIP-Metric
20​
33.21​
6.6​
12.5​
(116)
2227​
2756​
P315/60R2032 PSI28 PSIP-Metric
20​
34.88​
7.44​
12.91​
116
2227​
2756​
ISO Metric (SL and XL Ratings)
RCTIP
LandcruiserLX 570
110​
Tire Not Applicable36 PSIISO
0​
110​
1554​
2337​
111​
Tire Not Applicable35 PSIISO
0​
111​
1598​
2403​
112​
Tire Not Applicable33 PSIISO
0​
112​
1642​
2469​
113​
36 PSI33 PSIISO
0​
113​
1687​
2535​
114​
35 PSI32 PSIISO
0​
114​
1731​
2601​
115​
34 PSI30 PSIISO
0​
115​
1775​
2679​
116​
33 PSI30 PSIISO
0​
116​
1830​
2756​
117​
32 PSI29 PSIISO
0​
117​
1885​
2833​
118​
30 PSI28 PSIISO
0​
118​
1929​
2910​
119​
29 PSI27 PSIISO
0​
119​
1995​
2998​
120​
29 PSI26 PSIISO
0​
120​
2050​
3086​
121​
27 PSI25 PSIISO
0​
121​
2127​
3197​
122​
26 PSI23 PSIISO
0​
122​
2194​
3307​
123​
25 PSI23 PSIISO
0​
123​
2271​
3417​
124​
24 PSI22 PSIISO
0​
124​
2348​
3527​
125​
23 PSI22 PSIISO
0​
125​
2414​
3638​
110 (XL)Tire Not Applicable42 PSIISO(XL)110 (XL)
1378​
2337​
111 (XL)Tire Not Applicable41 PSIISO(XL)111 (XL)
1422​
2403​
112 (XL)Tire Not Applicable39 PSIISO(XL)112 (XL)
1455​
2469​
113 (XL)42 PSI38 PSIISO(XL)113 (XL)
1499​
2535​
114 (XL)41 PSI36 PSIISO(XL)114 (XL)
1532​
2601​
115 (XL)39 PSI36 PSIISO(XL)115 (XL)
1576​
2679​
116 (XL)38 PSI34 PSIISO(XL)116 (XL)
1631​
2756​
117 (XL)36 PSI33 PSIISO(XL)117 (XL)
1675​
2833​
118 (XL)36 PSI32 PSIISO(XL)118 (XL)
1720​
2910​
119 (XL)34 PSI30 PSIISO(XL)119 (XL)
1775​
2998​
120 (XL)33 PSI30 PSIISO(XL)120 (XL)
1819​
3086​
121 (XL)32 PSI29 PSIISO(XL)121 (XL)
1885​
3197​
122 (XL)30 PSI27 PSIISO(XL)122 (XL)
1951​
3307​
123 (XL)29 PSI26 PSIISO(XL)123 (XL)
2017​
3417​
124 (XL)28 PSI26 PSIISO(XL)124 (XL)
2083​
3527​
125 (XL)27 PSI24 PSIISO(XL)125 (XL)
2149​
3638​
ISO Metric
RCTIP
LandcruiserLX 570
107​
0​
107​
1433​
2149​
108​
0​
108​
1466​
2205​
109​
0​
109​
1510​
2271​
110​
36 PSI32 PSIISO
0​
110​
1554​
2337​
111​
35 PSI31 PSIISO
0​
111​
1598​
2403​
112​
33 PSI30 PSIISO
0​
112​
1642​
2469​
113​
32 PSI29 PSIISO
0​
113​
1687​
2535​
114​
31 PSI29 PSIISO
0​
114​
1731​
2601​
115​
30 PSI27 PSIISO
0​
115​
1775​
2679​
116​
29 PSI26 PSIISO
0​
116​
1830​
2756​
117​
29 PSI26 PSIISO
0​
117​
1885​
2833​
119​
26 PSI24 PSIISO
0​
119​
1995​
2998​
120​
26 PSI23 PSIISO
0​
120​
2050​
3086​
121​
24 PSI22 PSIISO
0​
121​
2127​
3197​
122​
23 PSI22 PSIISO
0​
122​
2194​
3307​
123​
23 PSI22 PSIISO
0​
123​
2271​
3417​
124​
22 PSI22 PSIISO
0​
124​
2348​
3527​
125​
22 PSI22 PSIISO
0​
125​
2414​
3638​
I would suggest taking a second look at all these ISO-Metric pressures - and split out the difference between SL (Standard Load) and XL (Extra Load/Reinforced) as they use different Load/Inflation tables.
HTH
