Tire Pressure recommendation
Good catch, By the time I was doing the ISO rated tires, I had sort of lost interest. For now I will update the title for that table to reflect that it is only for SL ISO-Metric tires.
I would suggest taking a second look at all these ISO-Metric pressures - and split out the difference between SL (Standard Load) and XL (Extra Load/Reinforced) as they use different Load/Inflation tables.
HTH
OK, but those pressures are incorrect for SL ISO-Metric tires. It looks like you might be using the LT-Metric design Load Limit instead of the P-Metric design Load Limit.
HTH
Edit to add: As an example, no SL ISO-Metric tire with a Load Index less than 113 would be applicable for use on the LC200.
If anyone needs the pressure for their 200 on 42s, please post pics also.
HTH
Thank you, always good to have a 2nd set of eyes. I was using a simple test to choose which load limit to use, and was only using the proper load limit for the 2 digit load ratings rather than all of them.
I've also updated the table to add the XL rated tires. Luckily the ISO tables are the most complete, so I didn't have to do an interpolation.
LT 285/75 R17 Load E BFG KO2, LX 570... have been running 35psi. Does this pass mustard?
Indeed it does.
The RCTIP for those LT285/75R17 tires on your LX570 is 35psi F/R.
HTH
Indeed it does.
HTH
Well @gaijin ...I tried. I'm sure these standard sizes you have memorized by now.
Sure!
The RCTIP for those Michelin LTX A/T2 tires in size LT285/65R18/E 125/122R on your 2015 LC200 is 42psi F/R.
HTH
Hi Gaijin...I just changed the tires on the 2019 lx570 21" to a 18" oe heritage edition rims with Michelin ltx at2 285/65/r18 tires these are e rated tires. What would be the tire pressure here
For a stock LX with 21” wheels what’s a safe air down tire pressure for off light off road conditions? Factory recommended for road is 33psi. Thanks!
The RCTIP for those LT285/65R18 tires on your LX570 is 37psi F/R.
HTH
