OK, if we are talking hypothetically, let's all get on thge same page so we might actually produce something meaningful with all this.
First,
@eizenjin91 you know you are over the allowable max weight for your vehicle - and that your weight is distributed too far forward. Let's assume we're not going to "fix" any of that. So ... yes, your tires probably need a little more pressure to support that weight.
@indycole has a pretty good idea, but I don't think it needs to be that complicated, and the numbers don't work for
@eizenjin91 LT285/75R17 tires.
Hypothetically, since we are talking about an increase in weight less than 5% (7385 pounds to 7720 pounds), we may be able to safely assume that any "safety margin" built in to the stock numbers does not have to increase proportionately within this small percentage increase. This might be an easier way to go:
(Gross Weight - GVWR) / 4(tires) = Amount additional Load Limit required.
(7720 - 7385) / 4 = 84 pounds/tire
Load Limit at your Recommended Cold Tire Inflation Pressure of 37psi = 2301 pounds
New Load Limit for 7720 pound Gross Weight = 2301 pounds + 84 pounds = 2385 pounds/tire
From the Load/Inflation tables for the LT285/75R17 tires:
- 35psi => 2215 pounds
- 40psi => 2430 pounds
| (2430 - 2215) / (40 - 35) = 43 pounds per 1psi
- 36psi => 2258 pounds
- 37psi => 2301 pounds [Your Recommended Cold Tire Inflation Pressure for stock GVWR of 7385 pounds]
- 38psi => 2344 pounds
- 39psi => 2387 pounds [Your Hypothetical Cold Tire Inflation Pressure for a GVW of 7720 pounds]
Hypothetically, of course
HTH
