Tire Pressure recommendation
Here’s one for you all. When I leave the house in the morning it is 19F outside, when I drive home it is 48F. My tire pressures are never right.
Toyota has you covered:
HTH
"Right" is the range your PSI cycles through based on cold inflation pressures. Changes throughout the day are impossible to avoid.
So you want to set your MINIMUM pressure, and that can only be set when tires are their coldest. Then, as temperatures fluctuate and the air expands/contracts, you can know with certainty that your tires will not fall below the cold, condensed-air minimum. If you can only inflate when hot, add a few pounds knowing it will decrease when cool again.
A wheeling example of cold vs. hot issues-
-It's pretty common to air down on hot trails days, and then as the day cools...or especially if you climb up and through snow...suddenly you are WAY flatter than you intended because you cool the air in the tires. But anyway--set it when "cold" and then no worries.
Great resource! Gaijin, can you provide a recommendation for 2015 LX with 275 55 20 Goodyear Wrangler All-terrain Adventure. These are p metric 113T. Tire shop put them at 40 psi. TIA.
Glad you find it helpful!
The Recommended Cold Tire Inflation Pressure for the P275/55R20 113T SL Goodyear Wrangler All-Terrain Adventure With Kevlar Product Code 758065571 on your 2015 LX570 is 32psi Front/Rear.
Knock down some of the excess pressure the tire shop put in those tires and enjoy the ride even more. Don't forget to initialize your TPMS.
HTH
@gaijin could you please help me out? 2016 LC with Nokian Rotiiva HT 275/60/20 115H. Thank you. You’re doing God’s work sir. Don’t take any guff from anyone.
Sure! The Recommended Cold Tire Inflation Pressure for the 275/60R20 115H Nokian Rotiiva HT tires on your 2016 LC200 is 33psi Front/Rear.
HTH
Sorry for this I could have overlooked it but PSi for 13 LX 570 for KO2 LT 275/55R20?
You're the first - no worries.
The Recommended Cold Tire Inflation Pressure for the LT275/55R20 tires on your 2013 LX570 is 46psi F/R.
HTH
Just put LT275/70/r18 KO2's on my '08 200. All stock right now. I'm thinking it's 42PSI F & R. Sound right?
Pretty close! The Recommended Cold Tire Inflation Pressure for LT275/70R18 KO2's on your 2008 LC200 is 41psi F/R.
HTH
HTH
Muchas Gracias!
Cold tire pressure for BFG KO2s, 275/65/18?
Thanks,
-Chris
I am forced to make assumptions - and I don't like doing that.
I assume you mean BFG All-Terrain T/A KO2 LT275/65R18/E 123/120R tires on a 200 series Land Cruiser. If so, then the Recommended Cold Tire Inflation Pressure is 45psi F/R.
HTH
HTH
You are correct, a gentleman, and a scholar. I appreciate it!!
-Chris
Almost wrapped my head around this, but a few questions:
Recommended pressures for 2015 LX570.
  1. PIRELLI SCORPION VERDE ALL SEASON PLUS Size: 285/50R20 116V XL
  2. PIRELLI SCORPION VERDE ALL SEASON PLUS Size: 275/60R20 115H
  3. BRIDGESTONE DUELER H/L ALENZA PLUS Size: P285/50R20 111V
  4. BFGOODRICH ALL-TERRAIN T/A KO2 Size: LT285/55R20 117/114T D Load Range: D Serv. Desc: 117/114
  5. BFGOODRICH ALL-TERRAIN T/A KO2 Size: LT275/60R20 119/116S D Load Range: D Serv. Desc: 119/116S
Currently running Stock 285/50/20 P Metric tires. Thinking about and upgrade, what are the Pros/Cons of going from Passenger to a Light Truck tire?
Thanks in advance,
Noah
  1. PIRELLI SCORPION VERDE ALL SEASON PLUS Size: 285/50R20 116V XL 33psi F/R
  2. PIRELLI SCORPION VERDE ALL SEASON PLUS Size: 275/60R20 115H 28psi F/R
  3. BRIDGESTONE DUELER H/L ALENZA PLUS Size: P285/50R20 111V 33psi F/R
  4. BFGOODRICH ALL-TERRAIN T/A KO2 Size: LT285/55R20 117/114T D Load Range: D Serv. Desc: 117/114 43psi F/R
  5. BFGOODRICH ALL-TERRAIN T/A KO2 Size: LT275/60R20 119/116S D Load Range: D Serv. Desc: 119/116S 40psi F/R
Thanks in advance,
Noah
Recommended Cold Tire Inflation Pressures are indicated in Red Bold above.
As far as pros/cons of P-Metric vs. LT-Metric, you will find a lot of opinions in other threads; but in general, some points to bear in mind whenever considering an alternate tire size/construction:
Any tire that is larger/heavier than the stock tire will result in:
- Slower acceleration
- Longer braking distances
- Lower gas mileage
LT-Metric tires usually have stronger (i.e. more puncture resistant) construction in both tread and sidewall.
Depending on size and construction you may also experience increased noise and interference (rubbing) with various body and/or suspension components.
Whether these trade-offs are acceptable or not is entirely up to you.
HTH
Thank you, but I'm a bit confused.
Wouldn't 116V XL Pirelli have a higher load index than the 115H so less air pressure necessary for for my LX's load? Or is it OEM size is OEM 33 pressure but the increase sidewall of the 115H lowers the pressure needed for the same load?
How does the does the XL affect the 116V rating? The XL would have a higher rating than non XL? If so how much limit is added/subtracted?
I'm babbling, but I almost had it until I looked at top and bottom simliar tire compares.
