Ah thank you for the info. Keep me honest, 41psi RCTIP for that same tire for a LC200?Yes, the RCTIP for an LC200 is different.
HTH
BFG AT KO2 LT275/70R/18 125/122R load range E
HTH
I have a 2013 LX570 and just installed BFG KO2s. What's the RCTIP for LT275/65R18 123/120R (Load Range E)? Costco filled them to 40psi. Thanks!
Hi @gaijin,
double-checking the tire shop’s recent inflation is greatly appreciated:
2011 LX570
BFG KO2
LT275 /65 R20 126S E1
Thanks!
36 psi! So Discount Tire was doing something right...although they’re hovering around 32lbs with the temps in CO so I may bump them up a few psi during the winter! Thanks!Sure!
The RCTIP for those LT275/65R20/E 126/123S KO2's on your LX570 is 36psi F/R.
What did the tire shop inflate them to?
HTH
@gaijin is amazing as those new to the forum are finding out! One of the best resources on this forum.
Which is why I am now turning to hi to double check the RCTIP for my snow tires which I had put on yesterday. Nokia Hakkapaletas (no, I did not spell that right) 285/60R18 R2 SUV. @gaijin?
Thanks for the kind words!
The RCTIP for those Nokian Hakkapeliita R2 SUV 285/60R18 116R SL tires on your LC200 is 33psi F/R.
Consider yourself double checked![]()
Hi @gaijin, I just put P275/65/18 114T Michelin LTX AT2s on my 2013 LX570. Please recommend the correct RCTIP(currently at 38 PSI) for these tires. Also do you mind sharing how you calculate this stuff.
Thanks in advance.
Thank you sir.Sure!
The RCTIP for those P275/65R18 114T tires on your 2013 LX570 is 28psi F/R.
Toyo tires published an excellent monograph on how to calculate the RCTIP for non-stock tires - find it here: Guidelines for the Application of Load and Inflation Tables
HTH
If my 16 LC door jamb sticker states that....
GVWR is 7385lb
GAWR
fr...3595lb
rear...4300lb
Why not just inflate the KO2s to satisfy the loading values for GVWR or GAWR?
if LC 200 has a GVWR of 7385lb, GAWR FRT are rated @ 3595, RR @ 4300lb why are the OEM tires are so much above the necessary capacity?
@gaijin would you also comment on this please. Asking to learn.
TIA
“On a different note when I called BFG for inflation recommendation I was told to inflate KO2s to 33 psi, that didn't make any sense to me either since LT tires are not rated under 35psi.”
