- Thread starter
- #21
Thanks for your reply and I’m well aware of the tire side of the equation. I guess sometimes it seems like folks obsess on the tire weight and forget the wheel.Yes, I read, and understood the original post.
From what I’ve observed, you seem enamored with the thought of the FCS F5 light weight, and reducing unsprung mass, but seem to ignore the less than ideal offset, and limited tire options. Less unsprung weight is good, but bad offset isn’t great. Weight savings between load range C and load range E is limited.
Do your thing, but you asked for thoughts (and I implied experience).
P-metric tires are just asking for flat tires.
These vehicles don’t require load range E, but they’re much more durable than P-metric tires.
Load range C is probably much more appropriate, but have very limited offerings for a 33” tire, except for a 17” wheel. There are few 5x150mm 17” wheels, with a reasonable offset.
The 51lb 17” (285/70R17) tire, is 9+lb lighter that the 60-62lb 16”(285/75R16) tire, on paper
I think that you’re “losing the forest, for the trees”, by locking in on wheel weight, ignoring wheel offset, and tire weight/options, but I’ll bow out now.
Toyo 285/75R16 load range C:
Pick your poison. Wheels/offset/tires/weight, but I’m using simple old school math.
Inexplicably, most auto manufacturers, don’t expect “enthusiasts” that push out the centerline ~2” per side, and use a BFH for clearance.
Luckily the FN 17” wheels seem to be very light and offer some great tire options at lighter weight as well.
Thanks everyone for chiming in!
