I know there isn't a lot of 100-series experience here but some general mechanicing experience might be useful.
I cannot get the timing gear to pull off the end of the crankshaft. I want to replace the crank seal since I'm already in there replacing the timing belt. I've got a puller on it. It's the type that threads into the pulley and a big center bolt that you turn to pull off the gear. But it's not budging. I've soaked it with WD-40 and it has sat overnight with tension on it but no luck. I was wondering if anyobody has any ideas on how to get the sucker off.
The last picture shows how the water pump was ready to be replaced. It's blurry but you can see the pink crud all caked up in the weep hole. I wonder if that leak cause a little corrosion on the crank under the timing gear and that's why it's being difficult.
If you're wondering what the blue towel is all about, that was to keep the stupid cats from getting up in that space overnight.
