Am going to attempt to finish our master bathroom shower. It is currently sitting in the raw with green board walls and a custom rubber tub. Here is what I have learned so far:
I need to wrap the threshold in metal lath
I need to lay deck mud for the shower floor.
I need to put up a vapor barrier followed by hardiboard followed by taping the seams.
I need to build in a bench and some shelves for the wife "products."
Dimensions are: 38"Dx55"Wx9'H
Here are some questions I have:
The tile shop recommends Deck mud for the floor. The home depot expert recommends topping sand. What's the difference for use in a shower?
How much slope should I build into the floor, existing is 3/4".
I have read tar paper is a good vapor barrier. The tile shop recommends craft paper or something called Redguard. What is best?
Should the hardiboard be installed before the deck mud or after the deck mud? In other words should I pour mud up against the hardiboard?
I would like to do a corner bench seat out of slate. How do you support a seat that large?
The plan is to use slate for the floor and travertine for the walls. I will also be deciding on some sort of design element to work into the tile.
Any and all ideas are welcome.
Thanks!
Thanks!
