That's the u-joint coupling at the gear box.That's the flex disk under the dash near the firewall, right? Where were you seeing the extra play?
check your couplings too.mine has excessive play at 45209-60070
there are two couplings.check both.mine had play at the lower coupling.the one that attaches the shaft to gearboxThat's the flex disk under the dash near the firewall, right? Where were you seeing the extra play?
It really is a massive improvementFinally got my steering box from RedHead running and @enox is absolutely correct- 0 slop at all. Nice and tight, so much less fatigue without having to adjust constantly on high speed. Holds high speed turns and straight lines solid without any play at all. Looking back, this should have been the very first thing I did to the 80 when I got it.
Did RedHead have to install any new parts, or could they just rebuild using the original ones? In other words, did it cost you more than the "normal" rebuild cost?Finally got my steering box from RedHead running and @enox is absolutely correct- 0 slop at all. Nice and tight, so much less fatigue without having to adjust constantly on high speed. Holds high speed turns and straight lines solid without any play at all. Looking back, this should have been the very first thing I did to the 80 when I got it.
I'm not sure about @2000cruiser but mine needed a new sector shaft which was an additional 150.00.Did RedHead have to install any new parts, or could they just rebuild using the original ones? In other words, did it cost you more than the "normal" rebuild cost?
The fee covers using your old existing rebuildable parts and them using larger bearings, oem seals, and other new hardware. As long as your shaft is not bent they should be able to rebuild it. Worth calling them if you want all the details around their work- it’ll give you some comfort.Did RedHead have to install any new parts, or could they just rebuild using the original ones? In other words, did it cost you more than the "normal" rebuild cost?
@2000cruiser and @enox, how many miles did you have on your steering box when you sent it out?I'm not sure about @2000cruiser but mine needed a new sector shaft which was an additional 150.00.
I doubt my PO ever had it rebuilt so mine had 250k mi.@2000cruiser and @enox, how many miles did you have on your steering box when you sent it out?
220k@2000cruiser and @enox, how many miles did you have on your steering box when you sent it out?
I’m thinking about this as well but their website looks like there are no cores so we would have to send ours in. Mine is my dd so I’m wondering how long it takes.I'm starting to think l should just pull the trigger on the box rebuild as it's certainly the most annoying thing I have going on with my truck. I'm at 167k miles, so I guess it's not out of line that it'd be worn.
What has this got to do with this thread? I don't mean to be rude but no one asked about data points, we're here to figure out what to do with the ones that DON'T track straight....96 FZJ80, 370,000 miles, original gear box (untouched), tracks straight down the road like it's on rails.
To be fair, I did ask the guys that had their rebuilt by RedHead how many miles were on theirs when they had it done. I was trying to get an idea of how long you should expect the box to last as mine has 165k miles.What has this got to do with this thread? I don't mean to be rude but no one asked about data points, we're here to figure out what to do with the ones that DON'T track straight....
I stand corrected.To be fair, I did ask the guys that had their rebuilt by RedHead how many miles were on theirs when they had it done. I was trying to get an idea of how long you should expect the box to last as mine has 165k miles.
