Thanks @TeCKis300 . If @tbisaacs is correct and my bt module is faulty, would it get removed anyway when installing an aftermarket unit? Do the Grom (or similar) units replace the entire bt module, or do they still rely on the factory module for certain functions?Weird that you're missing the BT phone connectivity.
An aftermarket BT adapter will solve both music streaming and hands free calling functions. Many on the market. Grom BT3 for Toyota/Lexus should do it.
Got it, appreciate the info!It wouldn't remove the stock component. It would create an alternate pathway for handsfree calling functions. The BT3 has its own separate mic.
No, I tried a few different ignition settings but all were in Park.You don’t happen to be in drive while the picture is taken do you?
No, no mention of BT through the audio menu.Is BT audio a source on the audio menu? It’s a backwards way in there as you should see a connect button once selected. Perhaps give that a try.
I'm also missing a few pieces of that roof track trim - it's not important and will not cause any leakage. There are threaded bolt holes in those tracks - some are used for your existing roof rails, some are covered. Those are the only "entry points" into the interior, and so long as those are sealed, you won't have water ingress.
I replaced almost all my roof rail trim since the little that wasn't missing was badly faded. It looks like you need 75551-60110 (left hand side). Right hand side is 75551-60111.
BTW, those threaded bolt holes at the front that were not covered due to the missing trim are where the LC roof rails bolt to. In case you haven't found that out yet, the LC rails are...
Yeah, that's not a bad price at all for what is probably a solid rack. That is one reason why I haven't invested more time/money in my current setup. It'll do for a while but I see a "real" rack sometime in the future.Thanks for the reply and the info/suggestion!
I have an ARB rack on order that I’m waiting on. The whole package was right around $700, which I think is reasonable. There may be a RTT in the future so I wanted something that could eventually serve as a base for it. If there was no RTT planned I would definitely go the LC rail route. I surf longboards and the LX rack is barely long enough to secure a 9’-0” board to without significant overhangs. Does Lexus think LX owners only surf short boards!?
ARB Roof Rack impressions?
forum.ih8mud.com
It’s been nearly two months since I’ve ordered it though...still on the boat from Australia apparently!
Not opposed to trying something new, but if I have to leave home to drop this off somewhere, I'd probably just have it wrapped in leather. I think that looks the best, but I was hoping to figure out a reasonable solution from home (hydrodipping, leather stitching, etc I cannot do myself).Hydrodip it and save yourself the trouble
