He said "gingerly".. That might not be the case. Don't be scared to put the effort into pulling up on it.
Haha yeah, I was careful despite what that first pic may suggest! You can see the towel in the first pic if you look closely...I cringed looking at the first pic. But I see you add the towel in the next.![]()
Are you saying that you couldn't get y our iPhone to connect to the LX Bluetooth?Last night I installed a GROM USB3 kit into the LX. The GROM website only lists the Toyota as compatible, not the Lexus, but it works fine. I got the USB3 rather than the BT3 because for some reason my Bluetooth was non existent from the infotainment screen.
I did add the Bluetooth module with the USB3 unit. My phone connects to it no problem and finally I can make hand free calls. It was actually your post about it that made me look into it, so thank you again!If you do change your mind and decide to add BT functionality, I think it's just a matter of adding this BT adapter to the USB3. I've had this Grom unit for years and it's working great!
My issue was that there was no Bluetooth/phone pairing option in my menu. The hardware is all there - the steering wheel buttons, etc, but the icon/button in the infotainment menu was nonexistent.Are you saying that you couldn't get y our iPhone to connect to the LX Bluetooth?
I was originally able to connect both phone and music to LX on my 2011 but then about 6 months ago something happened (iOS update maybe?) and I'm no longer able to connect my music automatically. Phone still connects automatically every time I start the truck without any issues but the music connection will not connect unless I go through the pairing again. As soon as I turn off the truck that pairing goes away for some reason. VERY frustrating because it used to work and then stopped.
Great write up. Can you provide the link to the exact USB3 kit you purchased? There are multiple ones on Grom website and I'm not sure which one is the right one.Lastly, run the mic cable. I mounted it up by the review mirror and ran the cord as shown below. I have not tested the quality of the connection yet, but this was a very easy way to run the mic - the majority could be tucked away without having to remove any panels.
So far so good - it uses the DISC/AUX button to activate, and it connected to my phone with no issues.
No problem, see below for links. Keep in mind that my OEM bluetooth mysteriously did not work, so I bought the separate bluetooth dongle. If yours works then I suppose you don't need it. So far no problems with the install. It's not as seamless as an OEM setup but no real complaints, it does the job well.Great write up. Can you provide the link to the exact USB3 kit you purchased? There are multiple ones on Grom website and I'm not sure which one is the right one.
Maybe try some buckshot. If you are in a neighborhood where that may be frowned upon, then maybe a pellet gun with a nice scope will work. It really depends on the size of the bird.Last night I parked under a streetlight and of course this morning there was some nice streaky bird s*** down the side of the quarter panel. I’ve tried soap and water, and per google, WD-40, but I still can see some remnants. Nothing discernible by feel, but still there visually. Am I screwed? Anything else to try?
A reasonable solution! I wonder what SDG&E would say about their streetlight that keeps going out!Maybe try some buckshot. If you are in a neighborhood where that may be frowned upon, then maybe a pellet gun with a nice scope will work. It really depends on the size of the bird.
Have you tried claybar?
