Tieing up loose ends on the V8 conversion part 823 (power steering)
Discussion in '60-Series Wagons' started by TheGr8Doughboy, Nov 19, 2005.
What type of fluid in the power steering?
  1. ATF
    5 vote(s)
    62.5%
  2. Power steering fluid
    3 vote(s)
    37.5%
  1. TheGr8Doughboy
    TheGr8Doughboy
    745
    Oct 18, 2004
    Rockville, MD
    So with the stock powersteering stuff you're supposed to run ATF. Now with the V8 conversion I'm runnin the stock gear and the Chevy pump (I guess that's obvious... but anyway) What should I be running?
    Thanks
    Chris
  2. Corbet
    Corbet Speski OffRoad LTD. Supporting Vendor
    4,240
    1,199
    Oct 22, 2002
    Durango, Colorado
    I have ATF in mine (same set up) No problems yet.
  3. Tinker
    Tinker
    2,865
    9
    Apr 15, 2004
    Larkspur, CO
    I changed my steering box because I thought it was the cause of my problems - the guy at the rebuilder (very knowedgable) said no diff between ATF & PS fluid. Since my Vortec's PS pump grew up on PS fluid I've stayed with it. Toy PS box hasn't complained in 1-1/2 years.
  4. Waggoner5
    Waggoner5 SILVER Star
    3,056
    207
    Sep 22, 2003
    San Clemente, CA
    I use PS fluid only in all my trucks. I figured there is a reason they make it.
  5. TheGr8Doughboy
    TheGr8Doughboy
    745
    Oct 18, 2004
    Rockville, MD
    Thanks... I was getting some leaking and I hoped it was from running the "wrong" fluid. I'm rebuilding the old steering gear currently. Ok, so it's torn down just passed the "carefully remove this peice w/o removing the bearings" stage and I'm slowly getting it back together....
    Chris
