You are definately on a roll![]()
Try MAPP gas rather than Propane to get some real heat.
too many BFH's on this thread, get a tie rod remover tool
I don't like the idea of BFHing on my sterring components
done this many times over seas when did not have a puller, heat.......AND could not replace the TREs but had to service front end seals....... loosen the castle nut just a bit to where it is flat with the threaded end of the TRE; put a jack under the castle nut with a block of hardwood and give it just a bit of upwards pressure with the jack; hold the ball peen against the female part with one hand then hit the ball peen with the BFH with the other...use eye protection as a chip might fly off the ball peenlarge ball peen held against one side of female link and strike 180 degrees with another ball peen, works every time.
old mechanic from the 30s taught me this one and
.........combination of upwards pressure with the sideways impact worked everytime and the TRE threads were not deformed........never take the castle nut completely off as the arm/link in tension can go up with a LOT of force
HTH
Lou
Now that sounds like a good idea. Problem is, I didnt read this b/f I cut the TRE off!![]()
HTH
Lou
For TRE removal, it is hard to beat this thing:
Where do you get that?
Been using the same fork for 20+ years. The fork can mess up the grease boot so the tool previously shown is better if you want to put together and take apart. Normally a one way street with tie-rods. Many times that tool won't fit but a pickle fork will.Only a few bucks for a pickle fork. 1 or 2 smacks and your done.Been using the same fork for 20+ years. The fork can mess up the grease boot so the tool previously shown is better if you want to put together and take apart. Normally a one way street with tie-rods. Many times that tool won't fit but a pickle fork will.
