** Original thread here **
So I decided to re-post this install under it's own thread. That way someone searching "thermostat", "overheating", etc. on Mud will find it.
Well it’s been hot here in SoCal the last few days. We hit 86 on Saturday and Sunday. Took the family out for lunch had the front and rear AC on high and the check engine light came on. I figured no biggie; it came on before when I needed to clean the throttle body. After lunch it was still on, drove home (3 miles) and just when I was about to turn it off I noticed the engine temp, pegged in the red, . Popped the hood and could hear the coolant boiling in the radiator. Since the drive was so short I’m pretty sure it did not overheat and the radiator did not boil over. Poked around on mud while it cooled down to see what could be the problem. Narrowed it down to two possibilities, thermostat or fan clutch. Went out and tried to turn the fan blade, it rotated about 1/8 of a turn and came to a stop, most likely ok. Gripped and squeezed both of the upper radiator hoses: the one just past the thermostat was easy to squeeze and felt empty of coolant. The other hose was hard to squeeze and felt like it was full of coolant. This lent me to believe a stuck thermostat was the source of my over heating problem. The thermostat is an easy and cheap first option anyway. A quick call to the local Toyota steelership and a 10% TLCA discount (always good to ask) and I was back in 15 minutes with $30 bucks in parts in hand.
Now I searched on Mud and no one had done a write up on how to change out a thermostat. I guess because it is just a basic item to replace no one thought it necessary to write it up. Well kids that’s about change.
Items needed-
1. New Toyota thermostat + a New Toyota thermostat gasket.
2. Large plastic catch container. (see below).
3. About a gallon of 50% mix of Toyota (red or green) coolant and distilled water. ** Check to see what color coolant your engine has. **
4. 10 mm socket with an 8 inch extension.
5. 10 mm open ended wrench.
6. Channel locks
Step 1: Place a large catch basin below the front of your engine. I’ve found these great plastic containers at Home Depot. They are black about 2 ft wide by 3 ft long and 12 inches high. They are used for mixing cement. I use this same container for my oil changes too. It’s the perfect size and catches just about everything that can drip out of your engine bay.
Step 2: Remove plastic engine cover.(unclip the hose on the driver side)
Step 3: Remove the top half of your airbox, (four metal clips).
Step 4: Separate the electrical connection on Mass Air Flow sensor (plastic clip).
Step 5: Remove the three or four tubes that attaches to the large plastic piece that is in between the air filter and throttle body.
Step 6: Remove the two bolts that secure the large plastic piece that is in between the air filter and throttle body.
Step 7: Remove the throttle body inlet tube and remove the entire large airbox to throttle body assembly.
Step 8: Locate the thermostat housing, passenger side tube to lower radiator. Use a pair of channel locks, squeeze and slide the hose clamp down the tube. You will want to slide this clamp far enough down the tube so that with your hand you can grab and hold the tube to wiggle it off the thermostat housing. Get ready for coolant to start pouring out when you remove this tube. I lost about 2 to 3 quarts while I was changing out my thermostat. It all spilled down the front of my engine and went into the large plastic container. I grabbed a couple of paper towels and stuffed’em into the hose end to keep the flow to a minimum.
Step 8: Remove the three nuts that secure the thermostat housing. (More coolant to exit the engine block and radiator tube when this is removed)
Step 9: Remove the thermostat, if yours is stuck in place use the channel locks to remove the thermostat.
Step 10: Install the new thermostat gasket on the thermostat and install into the thermostat housing. Install the thermostat so the "jiggle valve", as the FSM describes it, is located at the 11 to 1 o'clock position in the housing. It allows a little circulation until the thermostat opens.
Step 11: Repeat the previous steps in reverse order. One item to remember is to tighten the thermostat nuts evenly to make sure you get a proper seal. No not over tighten these nuts, just snug them down with the same amount force you felt when you backed them off.
Step 12: After everything is all buttoned up and back to the way you found it. Take a hose and wash down everything that the coolant could have dripped on. If you own any pets keep them away while you are washing the residual coolant away. They have a tendency to like the taste/smell of coolant.
Step 13: Open up your radiator cap and set it to the side. Place a funnel over the radiator and fill it. Keeping the radiator cap off, start your truck and move the interior heat setting to high but keep the fan to off or low depending on your vehicle’s controls. Monitor the coolant level in your radiator it will take a little while for your engine to heat up. Once it does the thermostat will open and the coolant lever in the radiator will drop. Top it off once it does and monitor for a few more minutes to make sure all the air bubbles are out of your coolant system. Turn off the engine and install your radiator cap. Then top off your coolant over flow bottle (if it needs it) and you are done.
** Check coolant level after 50 miles or so and top-off the recovery tank if needed. **
I hope this write up helps anyone else who may have some questions about this process. I learned not ignore my check engine light. I was lucky and only drove a short distance this could have been much worse.
Items needed-
6. Channel locks
