The official part number request thread (12 Viewers)
A piece of metal hit my front bumper on my '13 LC. Any idea what part this is? I believe it's part of the washer system that cleans the headlight.
VIN: JTMHY7AJ7D4013516
VIN: JTMHY7AJ7D4013516View attachment 3969258
That is your headlamp washer port. There is usually a cover that is painted the body color on top of the nozzle.. thing is the nozzle assembly isn't visible and that makes me wonder if the mounting brackets for it broke and the thing fell down inside the bumper.
You can go to the one on the other side and pull up on it to get an idea of how it works.. when you go to clean the lamps the fluid pressure forces the washer nozzles upward on something like a stem then when you're done a spring pulls it all back down to bumper level. You won't hurt it by pulling up a few inches.. it'll have a clear point that it stops moving.
That said, if the nozzle is ok and you just need the cap that is 85354-60050-B0 for a silver lefthand side. If you need the whole washer nozzle it is 85208-60060 for left hand.
You can get access to the nozzle by opening the fender lining skirt where it attaches to the bumper skin in front of the tire.. a few T30 torx screws on the side and a couple 10mm on the bottom, and the liner will move enough to get a hand in there. I know from experience the 10mm bolt that attaches the nozzle to the bracket is quite difficult to get to.. but it can be done with the bumper in place.
You can go to the one on the other side and pull up on it to get an idea of how it works.. when you go to clean the lamps the fluid pressure forces the washer the nozzles upward then when you're done a spring pulls them back down to bumper level. You won't hurt it by pulling up a few inches.. it'll have a clear point that it stops moving.
Wow @bloc! Thanks so much for explanation and help!!
A request please. The harness for the tow hitch, for power/lights/whatnot. Clearly caught this somewhere and its about time to address it. I assume its plug and play?
Request please. Front passenger side nut for KDSS for 2008 Land Cruiser. Just need the nut. Thanks!!
