thanks for the links for the heat shielding, when I get a new fan I will see if its possible to shield it somehow, perhaps a piece on the rocker cover, or on the base of the fan motor. I already have replaced the wiring with 50amp and a 40amp relay, and the fan is supposed to only draw 7amp. Also fitted a turbo timer to let it idle down to min temp before shutting down. I will move the relay to a cooler spot behind the headlights.
