Found some time to do the Radiator swap,
While I was in there I removed all the air con lines and cleaned up another bunch of cable, re ran/tucked the winch cables.
The lower rubber mounts didnt line up with the hole as its a HJ75 radiator, so I just through bolted in instead.
Seems to be working spot on , warm up time has been greatly reduced , thanks to having a thermostat. Fans turning on as usual at 80 degrees and temp cylced around there.
Cant say replaced the thermostat because there wasnt one in there before.
Several leaks , the old girl a little worse for wear.
Overflow mounted.
machined up some caps for the factory radiator rubbers.
bottom hose.Will build a custom one for the top at some stage just could bring myself to break the hose/sender seal again.
Pretty tidy with rubber bends anyhow.
