The Moonshine Motel (1 Viewer)
Help me design a new ramp door and I will! You have software that'll do FEA? I can draw it in fusion, but I want to test it digitally before I do.
FEA? Are the ramp designs that you are considering indeterminant? Are you concerned with fatigue life due to weight restrictions and the number of loading cycles? .... At work, we used CATIA to design and solid model every part of the aircraft to support a fully integrated electronic process. But, our stress/fatigue/DaDT engineers preferred hand calculations over the integrated FEA resources at hand. FEA was only worth the time and effort on a few parts where fatigue life/weight/fracture ... made the investment in FEA worth it. Typically, there is one design condition that drives the design for a part/assembly (configuration, material selection/sizing, ...) and it can be characterized in a static loading/stress analysis, with the remaining loading/sizing aspects being a fallout. Plus, these hand calculations were typically in-hand before the solid modeling was completed to feed the FEA tools.
Your work on Moonshine and Moonshine Motel have consistently demonstrated that the new ramp will be thought through and executed with skill-precision. CAD and FEA are tools that may be of aid to you, but your standards will ensure top results with or without 'em.
Good luck and please allow me to apologize for tossing my two cents in.
Ok, here is simple stupid idea #1…
-Open ramp and use a straight edge from the trailer to the tip of ramp.
- Evenly mark 8 or 10 spaces along that plane
- measure from the straight edge vertically to ground at each mark point
- cut a strip on 3/4 plywood that tall, and as wide as the ramp for each mark and horizontally attach it with hinges , across the bottom/outside of ramp to the other side, so it will swing down to act as a vertical leg when the ramp drops
- add a strip of 3/4 plywood on the inside where the tires will roll up it
- this theory works well in my mind, given that the ground beneath the ramp is flat /level
**please adapt this idea to actually work for you
Tick tock! :)
I'm not making it to fall crawl sadly.
Plans shifting with the motel. Definitely going to make it longer with a third axle, but extending it out the back. My f550 is stealing focus for now though, have some fun things planned for that to handle the weight better.
No one can guess a navistar engine? Come on.
Well I wouldn’t have had it on my list but a 466 would be an upgrade.
My odd idea #2…
Consider adding electric motors to the trailer axles and smothering the trailer with solar panels .
