Me thinks Johnny has scoped out the resale on Onan RV generators and has rightly decided it's a better idea to sell than have the overkill option. Trust me, when my 4k onan went out, I looked for a used replacement......they are not cheap.
I have a propane 5500 in our Toyhauler... Love it! I'd love to have a dedicated one for the house but just can't justify the expense for the once-every-other-year power outage that's significant enough to use it.
The guys on irate4x4 really don't want me to get rid of this diesel genset. They helped me come up with a solution I had not thought of before. Stay tuned.
Mine was gas, and it wouldn't matter where it was - you wouldn't want it running when you're trying to sleep. Personally, I'd sell it, and grab a portable invertor generator and don't install it. I have a westinghouse 2500 watt they make a 4500 watt one. It's basically a half priced honda clone. Grab a 100 foot or more extension cord and a padlock and heavy duty chain to secure it to a tree and put it downhill and as far away as possible. Your ears will thank you.
Ours is located under the overhang (under the bed) and it is noticeable when running but no more than the A/C that's directly over head. If we have the gen running, its to run the A/C so it kind-of cancels the generator drone out.
That seems like a great solution that will provide a good option for exhaust and you can insulate the hell out of it against noise. Just would have to make sure you have some way for heat to vent I guess. Hope you can get the Onan working there, because it gives you so much power capabilities for AC/Welder/tools, etc etc.
I was pondering this the other day actually. The mount plate has four large bushings built into it that support the motor off of the base, so it's not too bad. I was considering adding additional isolators under the base plate (between the base plate and the frame of the trailer), so it sounds like I should do that.
Genny freed from it's spot up top, and moved down to the floor, by way of a 4x4 ramp. It was only slightly sketchy.
After that, I finished gutting the goose area. We found a number of leaks where the caulk between roof panels has failed. Not a big deal to fix, but I'm glad to have found them now.
My sprockets and chain came in the mail, so this week I'll work on getting that system rigged up, then the generator compartment layout nailed down.
Haven't inspected it closely yet (really high up there, lol). There are a few small dents visible from the inside, and from what I've seen from the ground it's decent. Needs a good pressure wash though.
I'm thinking exactly what you suggested. Re-caulk the seams, then throw on some RV roof paint to help seal the whole thing up.
