Some time ago i started wanting a new roof rack, the one i had was to small, and had a high edge all the way aroung, so it wouldnt accommodate my roof tent (Overcamp).
My demands for a new rack would be:
-Must be very strong (carry at least 150kg at any given point).
-Size at least 210cm X 130cm. (82"X51")
-Low weight, no more than 40kg.
-Low profile.
-Should be easy to mount lights on.
-Should be of a rust free material (prefered), or with heavy duty coating.
Came up with three alternatives to suit my demands, Gamviti, Front Runner, or make one myself.
Front Runner is nicely built, and has dealers in europe, but its insanely priced.
Gamviti has a great design, but with shipping costs from Colorado to Norway it would turn out quite expensive in the end.
The third option, to build one myself was chosen, and i soon started planning what it shold look like.
I chose to steal some of gamviti's design, because it is a simple and strong design, and its easy to build if you are used to metal work.
I did some design changes and figured out to build it from salt water resistant aluminium alloy.
While i was looking at gamviti's roof rack i noticed he had some very nice mountings for the 100, so i purchased them.
The tubing the rack is made of is aluminum 6082-T6 32mm X 3.5mm, basket is made from 25mm X 3.5mm, stenght of this alloy is about similar to normal construction steel.
The main changes from gamviti's design are that its a bit beefier, more cross sections so i am able to walk on it without falling in betwen, and larger basket wich is removable on one side to be able to fit the overcamp (2m long).
Last weekend i finally came around to make this, and have worked on it several nights this week.
I finnished it last night and i am very pleased with the result, today, a landcruiser enthusiast and former 80 series owner came up to me and said this was the nicest 100 he had ever seen, and wondered where i had bought the roof rack
-Low profile.
all it does is hurt my feet.
