The Diesel Part number thread. NO CHIT CHAT or PARTS # REQUESTS! (3 Viewers)
3B Starter numbers
3B Starter numbers and cross reference
toyota 28100-56110 28100-56110
nippondenso 028000-7840 028000-7841
dixie S-8113 $233.00
wilson 91-29-5178
lester 16897
carquest 16897S
OCA lucas S9754
OCA Platium 16897
BBB 16897
Some numbers are the same but they all go to the same starter
lower rad hose heaters
(From [thread=256914]this thread[/thread], not OEM but very useful!)
1.5" lower rad hose heater, NAPA p/n BK 6053014
Part numbers (from Wayne, get NAPA to cross-reference) are:
Zero start
3200002 = 1 1/4"
3200003 = 1 1/2"
3200004 = 1 3/4"
12HT 12V voltage regulator
From Regitar - a US company. I picked this up from a local rebuild supplier today. Will probably work with other 12V alternators with vacuum.
Regitar U.S.A.
VRH2005-11
about $30
1HDT
BELT, V (FOR FAN AND ALTERNATOR)
90915-02452,
VALVE, HEADLAMP CLEANER - the flow back valve for head lamp sprayer
85031-30020,
GASKET, TIMING COVER
11328-17010,
SPRING, TENSION - Timing belt tensioner
90507-27003,
ROD & PIPE, SHIELD - Radio Antenna
86336-60040,
Disk Brake Pad Kit
04466-60020,Rear Axle
04465-60020, Front Axle
12HT
Air Filter - Beck/Arnley 042-1456
Oil Filter - Beck/Arnley 041-8193
H1 Headlight Lens BOSCH 0 301 709 001 - 730
Inexpensive Rebuilt Calipers
Factory part number for my '82 BJ42 (Australia): 47750-60021
www.thepartsbin.com -> 1982 -> Toyota -> Land Cruiser
A119826 A1 Cardone Front Passenger Side Brake Caliper 1976-1990 Toyota Land Cruiser (rebuilt) $34.76
A119827 A1 Cardone Front Driver Side Brake Caliper 1976-1990 Toyota Land Cruiser (rebuilt) $32.87
Core charge is extra. Another WorldPac site mentions these calipers are casting number: S12-8, which matches my truck. This looks like a great deal versus rebuilding yourself.
1hdt fuel filter cross reference (taken from MAK filters site)
Toyota part number 23303-64010
DRIVEJOY V91114000
MAK MK57164
WIX 33138
ALCO SP969
ASAS SPFC226
BALDWIN BF7532
BOSCH 147434281
COOPERS Z954
FIAAM FP5145
FLEETGUARD FF5307
FRAM P5138
ISUZU 5861024980
LUBERFINER LFF8806F
MAHLE (KNECHT) KC67
MANN & HUMMEL WK940/6
MAZDA 1N0013ZA5
MOTORCRAFT EFG306
NISSAN 16403059E00
PURFLUX CS439
PUROLATOR F57583
RYCO Z252
TECNOCAR RN141B
TOYOTA 2330264010
VIC FC226
WAKO LF28K2
Napa 3138
Donaldson P550385
1HDT Air filter
Toyota 17801-68030
WIX 42159
Amsoil 42159 (same number as WIX)
K&N E-2443
Donaldson P526756
Napa 2159
Interestingly, this air filter seems to the same for damn near all Landcruisers according to that Donaldson cross reference.
1HDT oil filter reference list
revised 1HDT oil filter list
Courtesy of "CruiserGord".
A list of all the part numbers of other brands cross referenced with Toyota Part number 90915 - 30002:
Sakura Oil Filter: C-1112 (Z334)
FRAM PH6357 and PH5123
WIX: 51368 This one is a shorter body, for a Camry/Corolla, but it fits.
WIX: 57254 is the longer body
Fleetguard: LF3608
AC-DELCO: PF30001
Hastings: LF191
ALCO SP993
AMC TO140
BALDWIN BD7029
BOSCH 0986452062
CHAMPION K274
COOPERS Z1043
CROSLAND 2109
DELPHI FX0125 and FX0163
FIAAM FT5429
FILTRON OP619/1
FLEETGUARD LF3608
JAPANPARTS JFO213
LAUTRETTE ELH4240
MAHLE GROUP OC275
MANN WP928/80
M-FILTER MH3352
NAPA 1368 <---???????? Should be 7254
NIPPARTS J1312013
P.B.R. BC1214
PURFLUX LS895
PUROLATOR L27635 and L37635
SOFIMA S3248DR
TECNOCAR RD1216
TJ FB5842
UFI 2324800
VIC C115
YUIL FILTER YFT011
When checking for other brands: the fliter requires a 24mm x 1.5 mm hole.
Clutch Booster 13B-T
This is the part number for the clutch booster for
a Cruiser with a 13B-T engine: 31440-60070.
31440-60100 will also fit and is easier to get hold of.
Cheers.
1HZ 1HDT Glowplugs
A few more numbers that may help...
It looks like it's the same glow plug PN for 1PZ, 1HZ and 1HDT (12V system, 11V plug)
Toyota/ Denso 19850-64031
NGK Y-715R
EIKO - GT220
Bosch - GPT220
Champion CH153
HKT - PT-152
NGK - Y-T02
Dreik DGP2042
Diesel Truck Part - DTP 02 597
11/84 (1985) BJ73V = 3BII engine
- glow plug # is 19850-68060 (Bosch 0250 202 076, NGK 2188 [Y-197 old #], ND 067100-1460) 14 V
- stock clutch fan and fan are smaller than BJ60 3B fan, but fan shroud will accommodate increased size (mounting flanges on fan clutch are the same).
HJ60 Batteries, Thanks Radd Cruisers!
Napa batteries, Group 27.
You'll want a 27C6 and a 27F6.
You can run the 27C6 in both locations as long as the wires reach and then you can swap them from side to side on occasion.
~John
3B Water Pump and Alternator belt -99343-01195 - Gates TR22472 (known as 25474 by NAPA)
No Gates relpacement availiable for P/S pump belt (99343-11510)
3B P/S belt idler pulley bearing - NSK 6302DU (sealed both sides)
3B Block Heater - ZEROSTART/TEMRO (Canada) p/n 3100021 (sold by Lordco and others)
3B AC belt 99322-01030:
Gates xref: 9412, 9412HD
ACDelco xref: 17412
