The definitive, "Found a good deal on CL" thread (1 Viewer)
that and all his other parts. posts twice a day for the last 10 months.
maybe we can all chip in? Poor guy need lunch money i guess.
I miss the guy with the torn up center console bass speaker out of the Lexus LX470 that he wanted like $170 for. Thought it was a joke, then realized he was possibly serious?
Land Cruiser Camper Kits & Storage Drawers - $295
More info at Cruiser Camper Co
Toyota Landcruiser FJ40
Anyone know this 40? Any recommendation for a mechanic (or MUD member) near "West Valley" I could pay for an inspection?
Interesting he still has this. V8 fJ40 FOR SALE Very nice cruiser and work was done by Dave Gore ( @lcwizard )
I shouldn't be surprised he still has it. I bought his other 76 and it was listed for sale here for a year before he bumped it again. It was a much cheaper cruiser. $18,000 back then was a lot more for a FJ40 then today.
The original thread stated it was sold, now it's back on CL, with his original photo's 4 yrs later; for the original price, not the reduced? Granted timing tends to be a big factor, 18k may work now?
Just looked at these today in person! Pretty nice design and seems well built. Nothing too sturdy or heavy duty as an ARB would probably be but for the price I thought it was a good deal/product. He already has a good bit of orders in just 2 days of having the ad on craigslist.
If you'd like to know more info PM me. Didn't ask if he was on MUD but he did mention that prices will probably go up next month
Where was it that you reviewed this... In Phoenix or elsewhere? Curious given the location outlined on your user name.
:lol: gold plated ?
this just popped up, didn't see it in the classified here yet.
1994 Land Cruiser, built and meticulously maintained - Expedition Portal
$12,500
Never thought this would happen but i just dont use it much anymore and could use something to tow. Many memories in this rig and best automobile me or my family has ever owned.
2nd owner since 165,xxx
Previously doctor owned and Toyota maintained. Always OEM parts!
Meticulously maintained by me since then. Used for what it was made for sometimes but also very much loved, never has missed a beat while everything else around it breaks. Land cruiser Legendary!
List setup:
3" lift springs: ome "J" front, Heavy rear
OME L shocks front, Fox shox 2.0's with remote reservoir and compression adjuster in rear
Slee castor plates
New oem front control arm to body bushings
Reinforced rear trailing arms
Adjustable rear panhard
SS brake lines from body to axle.
extended brakes, breathers, sways and all necessary parts for lift.
Extended bumpstops and sway bars
1.5" spacers on rear
Drivetrain:
stock T-case, fluid changed every year
4.88 gears
Front axle: E-locker, rebuilt completely at 175k ie. all new expect axle shafts and birfs. Birfs and bearings repacked 1k ago.
Rear axle: semi-float with Aussie locker.
4.88 gears, solid pinion spacer, nice and quiet
Transmission is great. New shift solenoids at 210k. fluid changed every 10k
Brakes: new rotors, pads, drums, shoes, OEM master cylinder, 5k ago
Driveshafts greased every 3-5k, double cardan front, Custom made with toyota parts and new u-joints
tie rod ends replaced at 180k
Engine:
221,xxx miles (documented), lots of highway miles. These engines make it over 300k routinely!
Synthetic every time since 180k every 5-8k, 8 quart sump
Alternator rebuilt
Starter rebuilt
recent plugs, cap/rotor (OEM), wires 210k
oil pump reseal 205k
cooling system: t-stat, hoses, silicon PHH, rad cap, fluid flush toyota red
new o2 sensors, 180k
new hi-flow catalytic converters
egr disabled but can be easily connected back
PAIR delete
new pcv
Fan clutch rebuilt (oem) with thicker viscosity fluid, never gets hot.
New battery
New Charcoal canister
A/c works great but the compressor bearing needs to be replaced. will probably do it soon
Silicon PHH with constant torque clamps
All vacuum tubes replaced @180k
Transmission
Has the bigger "bus" trans a442f
Fluid drain and filled every 10k or so.
New shift solenoids doneabout 5k ago
Shifts perfect!
Interior:
Superior cloth, manual interior in excellent shape
Non smoking passengers
Kenwood dvd screen with bluetooth, usb, aux
nice moderate system: diamond audio componenets, RF amp, Infinity 12" sub
husky liners front and cargo
heat and sound deadening in cab, drive one without and experience the free heater under your feet.
led lighting system in rear cargo area, very helpful
tailgate lined with custom made sheet metal replacing carpet, very useful if your a man or like man ****.
additional fuse block for always hot 12v in cab
tinted
Sleeping platform made for cargo that opens over 2nd row seats. currently been setting out side but u can have it if you want. its not too fancy, just particle board and a piano hinge.
Exterior:
It has seen trails so there is evidence of that. Nothing huge just some pin striping and one hit from a rock. Wax it and it still shines quite nicely.
Newer windshield with new oem gasket. One crack along the bottom.
Only one little bit of body damage behind pass rear wheel arch.
Does not leak water! Sunroof, windshield and rear windows have all been checked and fixed.
Metal-tech front tube bumper
Warn M8000 winch, needs a new controller
custom rock sliders with step
Slee copy rear with quarter panel protection, BEEF! also have a spindle for it but not installed
factory tow hitch 2 inch 5000lb capacity
no factory roof rack aka rust bucket
Yakima mega warrior with extension available
new wiper blades
HIR headlight bulbs
fog lamps mounted, not wired
Tires:
315/75 aka 35's:
Brand new Firestone Destination AT'S
Worth noting:
Ac compressor bearing needs to be done soon
Fog lights not hooked up
Fender flare holes taped up, needs a permanent solution, a fun project for you!
Radiator just sprung a leak. Will fix shortly or can negotiate into price.
I'm sure there is a few things i forgot but please ask. This is by far the best vehicle i have ever owned, wouldn't hesitate to drive across the continent. Only reason i am selling is i need a truck. Have all records and receipts including window sticker. Will also come with lots of spare parts and the Factory service manual BGB. Almost always used oem parts except in a few occasions.
Price is obo but not giving it away. This was gonna be a lifelong keeper so everything was done right!
Trades: GM 2500 truck, tundra, or anything that needs work plus cash.
Clean colorado title in hand.
attachment.php
attachment.php
again not CL but just popped up, it's on ADV so you'll need to log in to see the thread.
Yup, this is it.
The holy grail of toyota trucks. The one every one wants. Makes the girls (and guys) go weak in the knees and look upon you like a god.
Well, maybe it would be THE holy grail if it had a straight axle but the IFS works great for me!
It's name is "Burrito"
The low down and dirty:
Really nice, RUST FREE truck that I traded a 97 Land Cruiser for a few years ago. 218,000 miles on the 22re. Starts right up and goes down the road just fine. All accessories work, including the AC. Even the little button that let's you start the truck without the clutch depressed works fine. Transmission shifts effortlessly. Wiring harness is not butchered except for the addition of a cruise control that I cannot figure out how to use.
Xtra cab is really nice. I'm 6'2" and I do not have the seats as far back as they will go. Shaquille O'Neil could drive this thing with no issues. Interior is in great shape for the age of the truck. Seat is worn a bit but no tears or anything. Cover on the dash. Carpet is all there as is the headliner.
Recently replaced the starter. When I first got the truck I replaced the belts and the water pump with an OE Aisin pump.
Want to sell it because I got another Land Cruiser and I don't need it any more.
What Burrito needs:
It has an exhaust leak where the header meets the manifold. I have the little doughnut gaskets and it is an easy fix. Literally 1 hour with the appropriately sized socket wrench and about 24" of extensions.
Timing chain is a little rattley. I actually have GOOD parts to make the swap including a timing chain kit from 22re Performance. Also have an Aisin oil pump (while you are there...) and a new timing cover just in case the old one is a little scarred.
If I were going to keep it, I would also replace the front bronze spindle bushings. It does sounds like they are wearing out. It's only noticeable when the hubs are locked (duh)! I have only used four wheel drive once, last year when we had some ice here in the DFW. I will tell you that this thing went EVERYWHERE when most people were sitting in their houses, crying like little babies, skeered to go outside. I figured the light back end of the truck would be an issue but it wasn't.
Mr. T knows how to design a truck!
I do not regularly drive the truck. Did take some trash down to the dump last week and she fired up immediately after sitting for a month.
Price is $5,000 but there is some room. Will come with a bunch of Toyota tune up parts (plugs, wires, rotor, cap, etc.
index.php
index.php
73 three isn't a bad year. Some markets got a early version four speed. While we didn't get that four speed the floor and frame changed that year so that one could just bolt in. Not a big deal changing to disc brakes up front and no rear axle came stock with disc brakes so no harder then any other FJ40. The real question is does it have any rust. The most important thing when dealing with a FJ40. Because it doesn't have title I won't pay more then what I figure I could part it for and put some money in my pocket. Live auction they are hoping people will get caught up and pay more then would if they had some time to think about. If you go set the price you would pay and walk away if it goes over that price.
PS: I've had a 73 FJ40 for close to twenty-two years that I've never even started the engine. It was off the road for at least five years before that. Still rather deal with replacing all the seals and flushing everything out then deal with rust.
