bottombracket
Dennis, did you have to replace the input shaft on the h152?
First gear on H152 is synchronized. But i still tried the double clutch trick and it makes no difference. Most of the time it goes into first gear fine , but about 25% of the time it will only go in "half way". I need to start releasing the clutch, as i keep pressure on the shifter, and it will pop in with a little grinding.I know on some transmissions first gear isn't synchronized, so it helps to double clutch when you shift into first, even if you're not moving at all. Just let the clutch out in neutral for a second then try to shift in first.
Dennis,
Have you gotten anywhere with the transmission issue? Can you adjust the plunger rod out further to alleviate this difficulty going into first gear?
I’m super curious about RPMs with the H152
Have you run the ST Maxx before? What’re your thoughts and impressions? Great in snow and ice? Super loud or not so much?
Again, very nice clean work!
Hey dennis.
I had this exact same first gear grinding problem in an Hj61 with a 12HT and H55F. Before the problem showed up I had the fly wheel ground and the step re-machined into it, I also installed a new clutch, master cylinder, slave cylinder, pilot bearing and throw out bearing. I battled this problem for over a year, probably bled a gallon of fluid through the system trying to get rid of air bubbles. I droped the transmission again and changed out the pilot bearing a second time. I replaced the slave and master again and the problem got worse! Ryan from hill top Cruisers suggested I hadn't bench bled the master correctly and I should order another. So I order yeat another master put fluid in all its openings, let it soak for an entire day and then verrrrry gently bench bled it. After installing the 3rd master the problem was gone. To be fair I bench bled all the masters before installing them but the third one I bench bled just about as gently as you'd give a babby bird CPR
Dennis.Not yet. Although it feels a bit better now after driving it around a bit. Still not how i expect a brand new transmission to shift.
I took it out on a highway for the first time today (was super busy this past week and haven't had the time), and will post the results later today or tomorrow. I will bundle them in the same post as the tranny modifications.
Thanks for the suggestion, Russ. I was actually leaning towards this as well, as the clutch pedal feels VERY soft. Much softer than what i would expect on a truck like this. Its actually softer than my wife's Yaris. I have a power vacuum brake bleeder (same thing as dealerships use) that does an amazing job bleeding brakes. I used it on the clutch slave as well, but i didnt bench bleed them (either master or slave). Is there any reason why you bought new master cylinder (tiwce!) instead of just removing and bench bleeding the one you had on?
Anyway, i decided to stop flooding this thread with pictures and text, and combine them from now on.
Here are the mods i did to the truck to accept the manual tranny. I mostly used a similar approach as @Rock40 , with some improvements (in my opinion). Certainly not the easiest or the quickest way to do these mods, but i wanted to do them in the cleanest, most original way possible.
Dennis.
there are too major reasons to preform a bench bleed. #1 remove air #2 is to get fluid lubricating the sealing surfaces of the master before force and pressure are applied. if you do not bench bleed a cylinder that has been siting on a shelf for years on end what happens is the piston seal sticks to the cylinder wall and will tear or get damaged the first time you stomp on the pedal. in both instances the masters had damaged seals which I discovered after dissembling them. Both cylinders were brand new Aisin cylinders. for the third cylinder I filled all the hydraulic openings with fluid and let that fluid seep in for over 24 hours. then slowly bench bled it and when I say slow I mean sloooooow. The point of the bench bleed was more to work fluid through the cylinder and get it lubricated then removing air. I very much doubt your pedal should feel soft, the 60, 70, and 80 series manual cruiser I have driven all have had heavy clutches even with vacuum assist. For what my opinion is worth I think you either have air in your line (best case scenario) or your master is damaged, either from lack of lubrication on its first few pumps if its new or old age assuming its not new. Just to drive this point home I have seen the same scenario happen on a friends 1992 80 series break master. hope that information is somewhat helpful or at least gives you something to think about
Dennis,
Have a look at the attached images. They show where and how the vacuum reservoir and hard metal line is routed. Let me know if you need better photos, this is what I could get quickly.
I like the data you've put together so far. Sounds like it runs very nicely.
"Speedometer is off by about 5% due to bigger tires. Bellow readings are actual speed, measured by GPS:
100km/h - ~2050 RPM
110km/h - ~2250 RPM
120km/h - ~2450 RPM"
My 80 has 315/75R16's tires and 3:70 gears, also actual speed by GPS:
100km/h - ~2150 RPM
110km/h - ~2350 RPM
120km/h - ~2550 RPM
I'd love to ditch my 315's for 295's or even possibly 285's but retain the overdrive highway gearing. Keep us informed of your driving test(s) and whether you encounter any mountainous hills or similar to see how the H152 reacts/responds. I think you're doing a really great job with this and thank you for all of your documentation and willingness to share with us. Keep up the clean and solid work.
Great build. Toyota might use the "mystery sensor" to signal the 1VD to have a torque reduction when the transmission is in 1st gear. Heavy duty OEMs have torque reductions when a manual transmission is in lower gears to prevent over loading the powertrain.
