I have access to neither of those things.
I couldn't say exactly the space, but its minimal. Maybe 3/8 at the closest. With as much abuse this has had overs the I would say deflection is zero.Also @Stumpalama and @Cdaniel - what kind of clearance do you run between the skid plate and the trans/transfer? I imagine the assembly moves a bit under torque and I also suspect there would be some deflection of the plate under a big hit.
forum.ih8mud.com
Hey Rick,
I have both if you want to come up to the shop one day. ZIP 19460
Is there somewhere I could see some pictures?
Build - Lynchburg Lemonade, matzell's STW
I looked around on the Google search. (after making the second set) These look like the ones Mark sells @65swb45 I think they are stronger than the ones others are selling due to the fact the angles of the mounting points, both at about a 45 deg angle so they keep from bending back. Others...forum.ih8mud.com
starting on post 73 or so
I couldn't say exactly the space, but its minimal. Maybe 3/8 at the closest. With as much abuse this has had overs the I would say deflection is zero.View attachment 2124128
Not sure, but I would expect its .120 wall tube.Very nice - I guess maybe things move less than I expect... did Dave use .120 or .250?
I really like those. For now TJ flares will have to do.A tiny bit of filler to get rid of some deeper sanding scratches:
Paint and cutting some 3/16" fender welting that I forgot to take pictures of, but here is how they turned out:
