Build The '93 Troopy Hodgepodge
out of curiosity, what do you use for those hard to reach places? an extra set of longer tongs or MIG, TIG?
Ya I got three sets of arms/tongs for the spot welder. Still got to use the mig here and there. Using .023 wire, wire speed high and heat at about 18g.
Cheers
All cleaned up (sand blasted and rust ground out) and weld thru primer.
Time to start putting it back together.
Cheers
Hello,
Now that is some serious body repair.
Great attention to detail.
Keep up the good work.
Juan
Don’t think I posted this...
Windshield frame top and bottom plus floor pans and firewall body mounts. Cut out of a Prado. Wish the floor pans were better but still, everything helps.
Cheers
This is the LHS bottom of C-pillar. Reconstructed from my finger down and this is the first layer.
I am half way through the second layer which is the reinforcement layer. After that I can fit the rear floor crossmember.
Cheers
Getting really close to fitting this, I just slapped it in there for the pic, it’s not aligned.
Nearly done rebuilding the LHS C-pillar.
I am not working on this full time by any means, not even close. Lots going on in the shop with five Cruisers plus my 80 for after hours. These two pillars and rear floor support though is taking a lot of work. It’s probably (no it is) the most complicated rebuild on the body thus far. Perhaps in the entire body rebuild. I tried to demonstrate that with earlier pics of how this is built and how rotten it all was. Many layers and complex shapes. Feeling good though to nearly be done with it.
Cheers
Oh ya, made this piece to replace the rotten piece in the LHS tail light bucket.
And yes it takes time to make a simple piece like this from scratch. Got to remove rotten piece carefully, make template of new piece, cut it out & shape it, test fit and adjust/modify as needed. Check and make sure everything is aligned, tight and pulled together. Rattle can with weld through primer, weld it in and finally grind it back and clean it up.
Cheers
Are you drunk!?
Custom Troopy all the way! 😂
Cheers
Nooo sorry meant for the cost (my guesses anyways) could have either or. Trippy all day 👌
I know what you meant, you on a Land Cruiser forum though. 😉
Gwagens are nice, I would take one but I would rather have Tony’s Troopy.
Cheers
Cheers
I’d rather have his troopy too 😏
